Lucas dynamo
Miken
PostPosted: Wed Nov 05, 2014 8:51 am    Post subject: Lucas dynamo Reply with quote
On a Lucas C40 dynamo there are 2 spade terminals on the back.
A large one and a smaller.
Can someone confirm for me which is "F" and which "D"
Also;
Presumably the larger one is for a thicker cable?
What size wires should I be using for these connections?
Thank you
Mike
PostPosted: Wed Nov 05, 2014 9:59 am    Post subject: Reply with quote
D is the larger.
PostPosted: Wed Nov 05, 2014 7:37 pm    Post subject: Reply with quote
D = Dynamo (output)
F = Field (coils)
E = Earth (ground)
Rover P2
Morris Mini Traveller Mk2
Miken
PostPosted: Wed Nov 05, 2014 10:08 pm    Post subject: Reply with quote
Thanks for the replies.
Any thoughts on the correct wire size for dyno to reg?
DM
PostPosted: Wed Nov 05, 2014 10:22 pm    Post subject: Reply with quote
44/03 or 3mm csa is ok for 25 or 33 amps dependant on the type of insulation..
A handy guide for wire sizes is here -
http://www.autosparks.co.uk/index.php?content_page=42
Dobbin
PostPosted: Thu Nov 06, 2014 8:32 am    Post subject: Reply with quote
Here's a couple of handy links as well
http://www.12voltplanet.co.uk/cable-sizing-selection.html
http://www.batt.co.uk/upload/files/flexiblepvcsinglecoreautocablebs6862_1343379708.pdf
