Painting Round Windows
PostPosted: Thu Dec 18, 2014 11:45 am    Post subject: Painting Round Windows Reply with quote
I am quite a way through prepping the cab on my vintage lorry for spraying and am now planning masking off etc.
I have seen some restorers fit all the window glass / rubbers fist then mask off but other fully spray then fit the glass / rubbers.
Any opinions?
PostPosted: Thu Dec 18, 2014 11:57 am    Post subject: Reply with quote
I would imagine that it depends on the prep you've done. If the cab has been bare-metalled, I'd want primer and topcoats getting right to the edge of the window apertures, before the glass and rubbers go in.
Old Wrench
PostPosted: Thu Dec 18, 2014 12:04 pm    Post subject: Re: Painting Round Windows Reply with quote
Any opinions?
Even if you have not/are not going back to bare metal, a most common place for creeping rot is behind old rubber weatherseal on screens etc.
Additionally, any original mastic (such as Bostick, Dum Dum etc) will be extremely hard, fractured and letting water in and stay: = Rust!
Prep all the metalwork, as Rick states: and mask the whole apertures from the inside.
Well, apart from that, did you enjoy the play, Mrs Lincoln?
PostPosted: Thu Dec 18, 2014 12:32 pm    Post subject: Reply with quote
She has been taken back to bare and then built up from there. She has no glass / rubbers on her at all. My gut feel has been to paint then fit it all back on...carefully!
PostPosted: Thu Dec 18, 2014 12:38 pm    Post subject: Reply with quote
Yes I would prep / paint and only then refit the windows....
PostPosted: Thu Dec 18, 2014 1:54 pm    Post subject: Reply with quote
But what if new seals are not available?
kev
PostPosted: Thu Dec 18, 2014 4:43 pm    Post subject: Reply with quote
Old Wrench
PostPosted: Thu Dec 18, 2014 5:27 pm    Post subject: Reply with quote
kev
Then you seek out and buy new rubber profile sealing strip from such as:
http://www.coh-baines.co.uk/
http://www.classiccar-trim.com/phdi/p1.nsf/supppages/eastkent?opendocument&part=8
PostPosted: Fri Dec 19, 2014 10:21 am    Post subject: Reply with quote
I have never come across Baines before, they look very good. Thanks for the link.
