imperial21
Posted: Thu May 19, 2016 8:45 pm Post subject: Fixing my oil leaks |
Has anyone any tips on changing the tappet cover & timing cover on my super minx ? In particular undong and removing the cranshaft bolt and pulley ?
Thanks |
Posted: Fri May 20, 2016 3:03 pm Post subject: |
Wind plumber's sealing tape around the pulley spiral so that the casing is centralised befored you tighten it up. Then remove the pulley and replace it less the tape.
