Land Rover V8 on LPG
PostPosted: Thu Feb 19, 2015 9:29 pm    Post subject: Land Rover V8 on LPG Reply with quote
Just after a spot of advice, and I know a few others here are thus equipped.
Mine has an occasional misfire when on gas, probably after 6-7 miles into a journey, ie warmed up. It tends to splutter after accelerating away from coasting, or sometimes on bends. Fuel level doesn't make any difference. It doesn't always do it, it tends to rear its head when under load, again not always. You can plough along a motorway and rarely if ever have a problem.
Dad's had LPG cars and mentioned the importance of plugs and leads.
What specific plugs and leads do you recommend? Mine is a 3.9 Disco II.
Thanks, RJ
PostPosted: Thu Feb 19, 2015 10:20 pm    Post subject: Reply with quote
I ran a Vauxhall Omega for 150k miles on an Lpg conversion many years ago. LPG forces a higher HT voltage to fire the plugs, so HT components must be considered as consumable. Plugs lasted 10k miles max, ignition leads, 50k miles and I had to replace the coil packs twice in 150k miles.
Still worth the conversion price
emmerson
PostPosted: Thu Feb 19, 2015 10:53 pm    Post subject: Reply with quote
Rick, I've used LPG V8s for around 15 years now, and can confirm UKDave's comments. Use genuine OE distributor cap, rotor arm and leads, with Bosch coil, and replace them every two years, or every second plug change.
Also make sure the vapouriser is clean. There should be a drain plug at the bottom to drain out the so-called "heavy ends" to keep the liquid gas (if you see what I mean!) flowing.
And its worth checking your coolant temperature. if the vapouriser isn't getting hot enough the gas won't flow.
I'd go for ignition first though.
PostPosted: Fri Feb 20, 2015 9:27 am    Post subject: Reply with quote
Running LPG the ignition system has to cope with voltages some 25% higher than it was designed for. NGK produced a range of plugs designed for LPG , may be worth checking if they still do?
There are better leads available; in the 80's Bosch produced its CD ignition system as fitted to the Porsche 911 at the time; the CD ignition system was designed to work at a much higher HT as such the leads were a different spec, fitting a set of these will help.
In my expirience when something in the ignition began to fail, if ignored it just got progressively worse, to the point where I would get a backfire in the induction system Embarassed .....now the Vauxhall 2.0i L X20XEV engine uses a "hot wire" in the air mass meter, it basically changes resistance with air flow letting the engine management system how much air is going into the cylinders. Its also quite fragile and the induction backfire used to destroy it Confused
As the LPG system on my Omega was a simple single point mixer, loosing an engine management sensor wouldn't affect LPG running and to be honest it still ran ok on petrol, but would have the engine management lamp on permanently until I replace the air mass meter, after this happened a couple of times I just soldered a resistor in place to fool the engine management system. However had I had had one of the more complex LPG conversions they use info from the sensors so this wouldn't have been an option.
When I sold the car I removed the LPG system and sold it to a chap who fitted it himself to a Ford Galaxy , I believe its still going, the system must be 14 years old now!
PostPosted: Wed Jul 08, 2015 3:57 pm    Post subject: Reply with quote
A change of spark plugs sorted the (under load) misfire ok, for a while anyway. A much more violent cutting out while on gas crept in, plus a worsening petrol leak from the smaller replacement tank, led to me taking it to a specialist last week.
A new solenoid sorted the cutting out, and raising the pressure slightly has helped general running also.
The bad leak on the petrol tank is down to it rotting out, so it's away having a replacement fitted as I speak. Sad
PostPosted: Wed Jul 08, 2015 5:46 pm    Post subject: Reply with quote
The bad leak on the petrol tank is down to it rotting out, so it's away having a replacement fitted as I speak. Sad RJ
Hi Rick, what's this "rotting out" you speak of, on your Landy.....
New one on me Wink
Hope you get it sorted Cool
PostPosted: Wed Jul 08, 2015 6:05 pm    Post subject: Reply with quote
New one on me Wink
Smile agreed, rust is alien to most LR experiences I know ...
The cr***ily-made tank came as part of the conversion, it now has twin LPG tanks and a small petrol tank. I suppose it's lasted 6-7 years, I suspect the previous owner left it empty most of the time, causing condensation to rot it out even quicker than normal.
PostPosted: Wed Jul 08, 2015 7:04 pm    Post subject: Reply with quote
I sold an old 1982 911 SC years ago, it had stood idle for a couple of years, the chap I sold it too took it to a local supermarket to fill up, basically the bottom dropped out of the tank with a really neat line around the tank Embarassed
emmerson
PostPosted: Fri Jul 10, 2015 5:59 pm    Post subject: Reply with quote
Rick, just as a matter of interest I had my Range Rover engine rebuilt and slightly modified recently. It was fitted with new plugs and leads as a matter of course. I replaced the new leads after only 2500 miles to cure a persistent misfire. I used Land Rover supplied leads. It would appear that a lot of the so-called "performance" leads just look prettier because they're brightly coloured!
PostPosted: Fri Jul 10, 2015 8:35 pm    Post subject: Reply with quote
New tank now fitted, the original was actually fine inside (to my surprise), but it had rotted from the outside in, once the powder coating had let moisture in beneath it. It was in a very bad way, with several pinholes easily visible.
PostPosted: Mon Jul 13, 2015 3:26 pm    Post subject: Reply with quote
I know that LPG requires a 60% better spark than petrol, but I've never had to use special components to keep things running OK.
I currently have a 3.5 litre V6 OHC Mitsubishi Magna and a 4 litre push rod OHV Jeep running on LPG and have had no problems. It is accepted that LPG will give less mpg and less power than petrol. but having large engines I never know what I am running on unless I look at the position of the fuel changeover switch!
There are two types of gas induction here in Australia. The "cheap" way is for the gas to be injected into the air cleaner and the "expensive" way is for the gas to be injected into the cylinders (like the petrol). Both my vehicles use the "cheap" way and the one thing I have to be very careful about is never to have the engine backfire on gas because if it does, it blows the side out of the air cleaner.
Keith
PostPosted: Mon Jul 13, 2015 4:39 pm    Post subject: Reply with quote
Keith
Keith, it's the same in the UK; the cheap way is effectivly a simple lpg carburettor, and the expensive way links into the engine management system.
My omega had the simple cheaper system, misfires could and did destroy the airflow meter, which was the "hot wire" type. Of course the airflow meter was not used when running on lpg, but if faulty it meant the engine management was permanently on. So I bought some suitable resistance wire and solders a new length in when it next occurred Smile
emmerson
PostPosted: Tue Jul 14, 2015 8:14 am    Post subject: Reply with quote
Just as a matter of interest, my RR runs on a basic mixer set up, but I'm gathering bits together to fit a BLOS lpg carburetter as an experiment. This works like an SU carb, with a variable jet.
I've heard glowing reports of the BLOS so watch this space.
PostPosted: Mon Oct 10, 2016 5:28 pm    Post subject: Reply with quote
I was somewhat startled to spot that the large bracketry that holds both my underslung LPG tanks had badly rotted, to the extent that it wouldn't have been long before the assembly gave way completely Shocked Needless to say, the Disco's gone in for new mountings to be fitted to the tanks. I took it to the place that replaced my badly-rotted petrol tank last year, the smaller size type fitted at the time of the original conversion in 2005.
There appears to be a theme here.
If your LPG conversion is a few years old, have a good look at the securing brackets holding the tanks in place ... many have straps that secure the tanks, mine has an all-in-one cradle type affair.
Dipster
PostPosted: Mon Oct 10, 2016 7:03 pm    Post subject: Reply with quote
Powder coating!
I really have not had much success with it. It looks good new but, with time, tends to get damaged and water gets in. Resulting in rust that is not initially visible. when it is it is too late to do much other than strip the wretched plast off, tidy things up and re-paint.
I have had most of my Land Rover genuine accessories I had fitted when the vehicle was new suffer in this way. It seems your after market tank fared no better!
