Interesting and/or unusual modifications found
PostPosted: Tue Jul 07, 2015 11:13 am    Post subject: Interesting and/or unusual modifications found Reply with quote
Have you ever uncovered interesting and/or one-off modifications, made to your car by a previous enthusiastic owner?
PostPosted: Tue Jul 07, 2015 8:02 pm    Post subject: Reply with quote
The crankshaft main bearings on an Austin Seven are ball/roller bearings; I bought a car which was in running order, and as the engine seemed to be reasonably quiet and smooth, I continued running it for two or three years. When I eventually took the engine out for a rebuild, I found the rear main bearing was, in fact, a nicely turned block of wood!
PostPosted: Tue Jul 07, 2015 8:36 pm    Post subject: Reply with quote
Hi Mike
My father built his own wood lathe and the head stock was a block of oak with a steel spindle powered by a flat belt system, the fixed and free wheel discs were also wood; he drilled a couple of oilways down through the headstock and the oil seemed to have enough of a swelling effect on the oak that he didn't need to replace the headstock in all the years he used it and applied oil to the spindle kept the free wheel disc running smoothly.
PostPosted: Tue Jul 07, 2015 10:19 pm    Post subject: Reply with quote
The wings of my Austin Swallow are screwed to the timber body with wood screws and washers but when I came to remove them, I was amused to find that a previous owner had drilled holes in 2 pence coins instead of using washers!
I have kept them all but I'm not sure why Laughing Laughing
PostPosted: Wed Jul 08, 2015 10:54 am    Post subject: Reply with quote
There you go Ray, Inflation!!! They used to be "penny" washers! On a more serious note, I bet they didn't rust - despite being magnetic!
Paul
PostPosted: Wed Jul 08, 2015 11:26 am    Post subject: Reply with quote
On my Ford 7W, when the engine was stripped we found a lot of smaller gaskets made cut from a 50's ish corn flakes box. They were in surprisingly good condition!
PostPosted: Wed Jul 08, 2015 11:31 am    Post subject: Reply with quote
Pre- decimila - descimalis - decimilisati ... Before 1971, he could have got 240 washer to the £, instead of 50.
PostPosted: Wed Jul 08, 2015 1:33 pm    Post subject: Reply with quote
Wood seems to be a popular repair medium.
Brian M
PostPosted: Wed Jul 08, 2015 2:19 pm    Post subject: Reply with quote
My recommissioning of a Rover P4 60 after 25 years in a garage was coming along nicely until the core plug on the rear of the block started to leak. My local P4 expert said it was an engine-out job as there was less than 1 inch between the bulkhead and the block.
I had a final look at the gap before getting out the engine hoist, and noticed a ragged cut on the bulkhead above the bell housing, so I dived inside the car and removed the gearbox cover (four screws) and found a previous owner had made two vertical cuts in the bulkhead. The "flap" could be bent up, giving perfect access to the core plug. 15 minutes later the job was complete and the water was staying where it should!
Brian
PostPosted: Wed Jul 08, 2015 2:54 pm    Post subject: Reply with quote
Paul
I have used brass washers and screws for attaching the wings.
Early decimal coins...are they magnetic? I will have to confirm now because I didn't think the magnetic ones came in until more recently.
I believe it has been illegal to deface the coinage of the Realm for many, many years. I hope big brother isn't reading this or I may get a knock on the door. Perhaps even an early morning armed Police raid... Shocked
PostPosted: Wed Jul 08, 2015 3:00 pm    Post subject: Reply with quote
Obviously this guy decided on a "money no object" restoration
Pity he didn't have a clue.. Laughing
Some of the work done defies belief!
PostPosted: Wed Jul 08, 2015 3:09 pm    Post subject: Reply with quote
I have come across a Morris Eight E with a floor repaired with paper mache'. Quite an extensive area had been replaced presumably in attempt to save weight!
Another floor; this time in a Vauxhall Cresta which failed the M.O.T.
It hade been replaced in large part with a concrete screed!
Actually, someone had made quite a good job of it using chicken wire as reinforcement. Nice and smooth, no sign of rust and really quite strong... Laughing
Pity I don't have any photos.
PostPosted: Wed Jul 08, 2015 3:32 pm    Post subject: Reply with quote
2 pence coins
http://www.coins-of-the-uk.co.uk/dec2.html
In the middle ages, the penalty for defacing a coin may have resulted in being hung drawn and quartered. Now it is a likely to be fine plus an undertaking to watch Coronation Street.
Minxy
PostPosted: Wed Jul 08, 2015 5:52 pm    Post subject: Reply with quote
I recon I have seen that done dozens of times - holes cut in bodywork to access core plugs.
On a similar note but on a professional basis when I worked for the Audi factory rally team access to two of the gearbox bell housing bolts were through holes cut in the bulk head. Sililarly to make removing of the gearbox easier the top of the bell housing was cut off so it would slip past the track rod arm when removing the gearbox. The drive shafts were held on with three bolts the other three being replaced by dowels. Sometimes ' modifications' can actually be beneficial!
PostPosted: Wed Jul 08, 2015 7:22 pm    Post subject: Reply with quote
When I worked at a garage belonging to a guy who wore a Stetson I picked up some bad ideas. One day an elderly Colonel (complete with ruddy cheeks and handlebar moustache) brought in his Mk10 Jaguar for a "cheap" gearbox change.
The way to remove said gearbox is to pull back the carpet and cut off the tunnel. The gearbox can then be dragged out of the car, replaced with one from a scrapper, the floor welded and the carpet stuck back down.
Charge the old duffer for a proper job and hope he doesn't come back.
Is it any wonder I don't trust garages. Shocked
