christine lowery
Joined: 30 Sep 2009 Posts: 496 Location: wallsend tyne and wear
Posted: Wed Mar 18, 2015 4:38 pm Post subject: poly bush expert needsd |
hi all
i am looking for a supply of the polybush's for B&B caravan chassis
19mm od with 15mm hole and the tophat is 4mm by 28mm the loverall lengh is 18mm, and a steel insert that is 15mmby 11mm and 34.5mm long
emails are away to some of the makers so lets hope somthing is out there
chris  |
christine lowery
Posted: Thu Mar 19, 2015 5:17 pm Post subject: |
sorted
thank you superflex part no 1321kss
or cheeper versions on ebay
christine  |
christine lowery
Posted: Thu Mar 19, 2015 6:37 pm Post subject: |
the poly bush kits vary in price £9 for a set of 4 to £65 so i have ordered the cheep set for evaluation
christine |
david_rachel
Joined: 26 Nov 2012 Posts: 144 Location: High Wycombe, UK
Posted: Sun Mar 22, 2015 8:33 am Post subject: |
Superflex is a UK manufacturer, indeed it's Chris Witor's company, he of all the Triumph spares. He actually lives very modestly and ploughs his money back into the company developing new parts all the time. So we all ought to support him whenever we can  _________________ David Rachel
1978 Carlight Casetta
1995 Lada Riva 1.5 Est Red |
sheffieldcortinacentre
Posted: Sun Mar 22, 2015 10:57 pm Post subject: |
yes good stuff,
avoid flo-flex or what ever hes called this year poor fit/quality & poor service,
refuse to fit/use if supplied & not just on cortinas. |
christine lowery
Posted: Wed Mar 25, 2015 11:19 am Post subject: |
the ebay cheep set came yesterday they are a fit and will do the job I never recommend any part just say there is an alternative to the bit that's not obtainable or very scarce
chris  |
Posted: Sun Mar 29, 2015 8:59 pm Post subject: |
| just saying as a warning as the company has changed names at least due to problems with their products. |
DELETED Guest
Posted: Sun Apr 05, 2015 10:20 pm Post subject: |
| DELETED |
christine lowery
Posted: Wed Apr 08, 2015 7:23 pm Post subject: |
caravan parts are sold out
thats why we searched for alternitives
Triumph tr6 front wishbone set will do the job
chris  |
emmerson
Posted: Sun Apr 12, 2015 5:59 pm Post subject: |
Chris,today I fitted the set I had from you last week. No problems really, except that as you said, the steel bush is slightly too long, and as I had to cut off the old bolts, I fitted 12mm new ones, so had to drill out the holes in the arm.
About two hours work.
Cheers |
christine lowery
Posted: Tue Apr 14, 2015 4:34 pm Post subject: |
thanks for the info Emmerson that's another spare ticked of the list
alla stripped the wheels of jacks van and we looked at the B&B spring its nowt like the one colin gave you so I took the measurements
chris  |
emmerson
Posted: Tue Apr 14, 2015 8:43 pm Post subject: |
I thought that spring wouldn't fit. I don't know what CP did with the old one, or why he bought those odd ones, and he is very vague about the job in general!
He's still got my brake shoes on his van too! |
