Replacing wheel arches which have rusted catastrophically
Goto page 1, 2, 3, 4, 5, 6  Next
Rivet_101
PostPosted: Fri Sep 29, 2006 10:31 am    Post subject: Replacing wheel arches which have rusted catastrophically Reply with quote
The wings of the Austin 101/Morris J and JB are bolted to the arches, which form and integral part of the van's sides. My cab has catastrophic tinworm, so these arches were very badly corroded and when I talked to my guru, Iain McKenzie, he suggested cutting them out altogether and fabricating replacements, which could then be welded in place.
Elsewhere on this forum you can see pictures of Iain showing me how to make the parts.
I have just finished welding the parts into my cab and thought that some of you might be interested to see what I did.
Let me apologise in advance for the size of some of these images. I still haven't found out how to compact them.
The first image shows the underside of the side scuttle of the cab.
Rivet_101
PostPosted: Fri Sep 29, 2006 10:33 am    Post subject: wheel arches Reply with quote
This is inside the driver's side of the cab and you can see the state of the now very feeble arch.
Rivet_101
PostPosted: Fri Sep 29, 2006 10:34 am    Post subject: the door-close arch Reply with quote
Rivet_101
PostPosted: Fri Sep 29, 2006 10:35 am    Post subject: cab's side surgery Reply with quote
Rivet_101
PostPosted: Fri Sep 29, 2006 10:36 am    Post subject: clean metal up Reply with quote
Rivet_101
PostPosted: Fri Sep 29, 2006 10:38 am    Post subject: adjustments Reply with quote
I spot welded two of the fabricated parts together, as well as bolting them to the wings......just to ensure there was no slippage.
Rivet_101
PostPosted: Fri Sep 29, 2006 10:40 am    Post subject: fitting before welding Reply with quote
Rivet_101
PostPosted: Fri Sep 29, 2006 10:41 am    Post subject: tack Reply with quote
clamp and tack
Rivet_101
PostPosted: Fri Sep 29, 2006 10:43 am    Post subject: tack Reply with quote
(close up on the captive nuts, which will be essential in the lower/front part of the arch which is enclosed)
Rivet_101
PostPosted: Fri Sep 29, 2006 10:44 am    Post subject: quick check for penetration Reply with quote
Rivet_101
PostPosted: Fri Sep 29, 2006 10:47 am    Post subject: weld Reply with quote
Be Kind! Sad
This is only my second weld experience ever, the first being a patch on a wing.
The top line is internal; the bottom is penetration from the outside, where the bottom of the trimmed side is secured to the arch.
Rivet_101
PostPosted: Fri Sep 29, 2006 10:49 am    Post subject: welding the side of the van to the fabricated arch Reply with quote
Rivet_101
PostPosted: Fri Sep 29, 2006 10:51 am    Post subject: off-side arch cleaned up Reply with quote
Not too much distortion. I am fairly confident I can hammer any concaving out.
Rivet_101
PostPosted: Fri Sep 29, 2006 10:53 am    Post subject: wing and internal part of wheel well shown in place Reply with quote
Rivet_101
PostPosted: Fri Sep 29, 2006 10:55 am    Post subject: wings Reply with quote
wings bolted on (rather than propped up with bricks!!) for the forst time in decades!
(excuse the quality. It is a camera photo)
Page 1 of 6
