eBay item number:171775560658
PostPosted: Tue May 19, 2015 11:45 pm    Post subject: eBay item number:171775560658 Reply with quote
Interesting old motor but what is its registration?
No connection with the vendor!
Paul
Penguin45
PostPosted: Wed May 20, 2015 12:25 am    Post subject: Reply with quote
HERE.
P45.
PostPosted: Wed May 20, 2015 8:59 am    Post subject: Reply with quote
Interesting motor, my Grandfathers first truck was a Model T. Is that not the remains of the reg number painted on the scuttle?
PostPosted: Wed May 20, 2015 9:36 am    Post subject: Reply with quote
Well it's not XI 391 as stated in the description. Would IX 391 be an Irish registration?
PostPosted: Wed May 20, 2015 10:10 am    Post subject: Reply with quote
IX is a Longford County Council number - Southern Ireland, so it would probably not be able to register it with that number in the UK (although I did have a Herald with a Dublin number registered in the UK!)
PostPosted: Wed May 20, 2015 10:31 am    Post subject: Reply with quote
Peter, you got my point! I suspected mit was Irish but did not have my reference document to hand!
If that is the case can it have a V5?
paul
PostPosted: Wed May 20, 2015 10:42 am    Post subject: Reply with quote
Firstly, this is a 'TT' and not a 'T'. It is the 'Ton Truck' version of the Ford Model T, and has the same power plant and transmission as the cars, but gains its carrying ability by having an overhead worm drive rear axle assembly. Although a few different ratios of worm drive were available, none gave the trucks anything like the speed of a standard car. Generally 18 to 22 mph. could be expected.
The rear wheels certainly look odd. They appear far too small, and that again would affect maximum speed. The TT was first sold in late 1917, and was equipped with wood-spoked artillery wheels all round, often with solid tyres on the rear, sometimes solids all round.
The front wheels have demountable rims. These were not an option until about 1923, so are a later addition if the 1921 figure is correct. Non-self starter T's and TT's were available up to about 1925, but as the starter was optional equipment from 1921, the casting of the transmission cover had a place for the starter, but with the holes blanked off.
It is a pity that there is no photo of the engine, as that would help with dating. The engine number would also help.
Recognising that the body would be a British-built one, the mudguards, bonnet, scuttle etc., would be ex factory. To me that part of the body work suggests a date of 1924/25.
I find the terminology of a 'Woodie' rather odd. The body is simply a tray-truck or lorry body, and certainly would never have been referred to as a 'Pick-up'.
