timing/ throttle lever clamp lock design help!
Rdover
PostPosted: Tue Jun 02, 2015 12:18 pm    Post subject: timing/ throttle lever clamp lock design help! Reply with quote
I recently figured out, more by chance than design, that my Alldays starts perfectly from stone cold without any choke whatsoever so I can either repurpose the choke lever (nasty home made affair) as a fast runner or make a clamp that I can use as a 'stop' for the hand throttle lever. This needs to fit around the brass ring and clamp in place using a thumb screw affair so I can adjust its position. And it needs to be brass.
Obviously I will need to make it myself but I'm looking for design ideas.
The ring is 2cm wide, 4mm thick and the stem for the throttle lever needs to be about 2cm high. Ideally it should also fit totally around the ring so I don't lose it too easily!
Richard
