What is the best way to repair a stress fracture
Nick57
PostPosted: Wed Oct 14, 2015 5:32 pm    Post subject: What is the best way to repair a stress fracture Reply with quote
We have old banger runabout (98 Corsa) that cracks on the b post level with windows.
I welded it up last year after being there for 4/5 years and it cracked around the weld.
Has anybody had this happen on a classic and how did you repair it. I am sure somebody has the knowledge to share on the best course of action
I am tempted to make a repair panel to cover it and fully weld that.
Thanks
Nick
Current Riley 9 Peugeot 505 Moto Morini 350
Have owned Aston Martin Inter Rudge Ulster Renault 4 Rover 100 Austin 7 Aston Martin Le mans
PostPosted: Wed Oct 14, 2015 6:36 pm    Post subject: Reply with quote
The welding process actually creates more stress especially MIG which is harder and less flexible.
Cutting out, gas welding and annealing a reinforced patch will cure it and drill a hole at the ends of the crack and reweld
Rover P2
Morris Mini Traveller Mk2
PostPosted: Wed Oct 14, 2015 8:51 pm    Post subject: Reply with quote
If it's any comfort it seems they're prone to it. I have a similar Corsa and, wondering if there were any particular weaknesses I should look out for, asked the MOT tester - decent bloke - what they normally fail on and it was one of the first things he came up with.
ka
PostPosted: Thu Oct 15, 2015 7:52 am    Post subject: Reply with quote
Wherever you can, avoid a butt weld, use a patch.
KA
Better three than four.
Nick57
PostPosted: Thu Oct 15, 2015 8:52 am    Post subject: Reply with quote
Thanks guys
You have confirmed what I thought that a patch is the best way to repair it.
I will have to find somebody local to gas weld it after I have made the patches.
Nick
