Posted: Wed Apr 06, 2016 2:37 pm Post subject: Quick question about a die |
Afternoon all,
Quick question - just looking at a 5/8" die sat on my desk here.
The threads on one side (the face that has the size markings written upon it) gradually appear to their full depth after 2 or 3 goes around, while on the reverse side the threads run almost flush to the face, with a more pronounced chamfer as the face is reached.
Which side of the die is presented to the bolt thread first? I assume the former, easing it on gently rather than with the full depth of the thread from the start?
thanks, RJ _________________ Rick - Admin
Posted: Wed Apr 06, 2016 3:44 pm Post subject: |
Correct, it helps getting everything square
Kleftiwallah
Posted: Sat Feb 04, 2017 5:59 pm Post subject: |
I have a small Myford and it is invaluable for setting up a die square. with the work in the chuck and the die held square by the tail chuck.
Cheers, Tony.  |
jp928
Posted: Sun Feb 26, 2017 7:33 am Post subject: |
Whatever you plan to cut a thread on, at that size and coarse thread, it will take quite a load to get the die to bite if its starting on a 5/8" dia part. Suggest you machine a taper on the end (on excess material you can remove later) to allow the die an easy start. I had a lot of trouble getting an M10 die to start recently until I had a taper.
jp 26 Rover 9 |
