Raggedy Crayford Mini rag-top, bring a shovel
PostPosted: Wed Apr 06, 2016 3:38 pm    Post subject: Raggedy Crayford Mini rag-top, bring a shovel Reply with quote
Hi all,
By gum, this spectacularly ropey - but mega rare - Mini will test the skills of even the best restorer out there. Maybe it'd be more suited to being used as a donor for a build using a better standard bodyshell as a starting point, although then the finished article couldn't really still be called a pukka example - or could it?
Fancy leaving it outside all that time Sad
http://ebay.to/207quNU
Fluffle-Valve
PostPosted: Wed Apr 06, 2016 5:36 pm    Post subject: Reply with quote
Bit I like the most is the quote. >> "Please note this is very delicate and will need careful removal."
Don't even breath on it. It'll fall apart if you do.
PostPosted: Sun Apr 10, 2016 8:40 am    Post subject: Reply with quote
Over £1k now, reserve not met ... looking at it, you'd almost have to dig the earht out underneath it, build a wooden frame to attach it to, before even thinking about moving it. Such a shame.
PostPosted: Sun Apr 10, 2016 11:03 am    Post subject: Reply with quote
i don't think there is a cats chance in hell of moving it in one piece! It will never sit on its wheels without snapping! The important thing will be to not damage any unique bits more than they are, and try to retain or identify any reference measurements. The end result however good is going to be far from original!
andycars
PostPosted: Sun Apr 10, 2016 6:45 pm    Post subject: Reply with quote
One for Time Team to exhume I think!
