Turn on a sixpence
PostPosted: Fri Apr 08, 2016 12:28 pm    Post subject: Turn on a sixpence Reply with quote
ROVER
One of Britain's Fine Cars
PostPosted: Fri Apr 08, 2016 9:28 pm    Post subject: Reply with quote
Could be good for emergency stops too!
Peter Laughing
PostPosted: Fri Apr 08, 2016 9:36 pm    Post subject: Reply with quote
I remember seeing a clip from the USA in the 1940s/1950s, of a car that had wheels that descended from beneath the chassis, enabling it to drive sideways into a parking space. It's probably on Youtube somewhere.
goneps
PostPosted: Fri Apr 08, 2016 11:01 pm    Post subject: Reply with quote
Almost as good as a Triumph Herald!
Riley Blue
PostPosted: Sat Apr 09, 2016 7:59 am    Post subject: Reply with quote
Must be front wheel drive.
David
1963 Riley 1.5
1965 Riley 1.5
PostPosted: Sat Apr 09, 2016 8:59 am    Post subject: Reply with quote
Where does the back seat passenger come from?. He suddenly pops up from nowhere.
Fluffle-Valve
PostPosted: Sat Apr 09, 2016 9:12 am    Post subject: Reply with quote
He walks up and gets in. It's just the film jumping.
PostPosted: Sat Apr 09, 2016 12:34 pm    Post subject: Reply with quote
More detail here.
http://citroenvie.com/was-citroen-first-with-parking-assistance-back-in-1927/
PostPosted: Sat Apr 09, 2016 3:42 pm    Post subject: Reply with quote
I don't think so! I suspect they just independently brake one wheel at the rear.
Kenham
PostPosted: Sat Apr 09, 2016 5:32 pm    Post subject: Reply with quote
One rear wheel is going in the opposite direction to the other, can't see how that can work if it is driving. As the passenger suddenly appears from nowhere the wheels turn, driver just sitting there doing nothing, looks a bit strange to me, don't think it will catch on.
Riley Blue
PostPosted: Sat Apr 09, 2016 7:05 pm    Post subject: Reply with quote
Complete brain fade on my part, front wheel drive in that would be the engineering marvel of the age!
David
1963 Riley 1.5
1965 Riley 1.5
PostPosted: Sat Apr 09, 2016 7:32 pm    Post subject: Reply with quote
On another piece of film, via my previous link,
it looks as if the driver reaches down inside the car. Perhaps he could apply the brake to either the left or right rear wheels. This would determine which wheel turned and set the direction of travel (clock or anti) clock. Driving on the Right Rear would tend to push the car anti clockwise.
There is some debate on the web, as to the make. Citroen or Peugeot.
Also via the same link, a close up of the front wheels as they turn through 90 degrees.
PostPosted: Sat Apr 09, 2016 7:55 pm    Post subject: Reply with quote
It looks like one of these to me
http://www.oldclassiccar.co.uk/citroen-typea.htm
PostPosted: Sat Apr 09, 2016 7:58 pm    Post subject: Reply with quote
I think it is a Citroen, would need to see a Peugeot to compare.
goneps
PostPosted: Sat Apr 09, 2016 11:27 pm    Post subject: Reply with quote
How the tie rods were extended remains a mystery, but I'd guess the drive was logical enough. With the front wheels almost at right angles there would be considerable resistance to forward or backward motion, therefore as the crown wheel tried to turn the only motion possible for the differential gears would be to force the half shaft gears to turn in opposite directions. One side would have to turn more than the other, otherwise the crown wheel would not move at all.
Turning in the opposite direction could be accomplished by using reverse instead of first. I think the key to this is that the front wheels turn through less than 90°, thus allowing slight initial motion to get things moving.
Extremely stressful on the diff., though, as someone's already remarked—and presumably a lot of clutch slipping as well.
Richard
