Triumph Roadster
PostPosted: Wed May 04, 2016 12:45 pm    Post subject: Triumph Roadster Reply with quote
This Triumph Roadster featured in Ricks headder. What are your thoughts about the engine? how do you rate reliability over originality? As usual - no connection with the vendor
http://rover.ebay.com/rover/1/710-53481-19255-0/1?toolid=10026&campid=5336732204&type=3&ipn=psmain&kwid=902099&kw=cb&mtid=839&icep_vectorid=229508&icep_item=311605221412&icep_ff3=2
PostPosted: Wed May 04, 2016 3:54 pm    Post subject: Reply with quote
The earlier Triumph Roadsters used the 1776 cc OHV engine also used in the 1½litre Jaguars. Later Roadsters used the 2 litre TR2 engine.
The 1776 cc engine has really stupidly designed water manifolding and spares such as shell bearing are a bit thin on the ground.
The 2 litre engine is used in so many places that spares are no problem.
Fitting a BMC engine would certainly not be good for the car's value.
PostPosted: Wed May 04, 2016 5:57 pm    Post subject: Reply with quote
Seems to be a strange conversion: if you want easy spares, why go for the 1600 MGA engine instead of an MGB unit? And as Peter has pointed out, a TR2/3/4 engine would be just as practical, and more authentic ...
