BigJohn
Ellis
Posted: Wed Aug 10, 2016 7:26 pm Post subject: |
A 1972 K registered chrome bumpered MGB would look like the one in the advert. It has the correct matt black grille, bumpers and as said was reshelled in 1992 presumably with a new Heritage bodyshell.
There were no factory built MG's with a V8 engine until the first MGBGTV8 in 1973 and no V8 roadster until the MGRV8 in 1992. The factory MGBGTV8 was powered by a detuned 3.5 V8 from a (Mark One) Range Rover.
Conversions of this type were often undertaken by enthusiasts and professional engineers. Chris Goffey formerly of Top Gear converted his own MGB to V8 power. A friend of mine built a MGB V8 from a genuine 1976 MGBGTV8. I don't recall that he had to make any modifications to install the V8 engine in his new Heritage bodyshell.
The success of the conversion depends on the 3.5 V8 used. Those from Mark One Range Rovers have the low compression V8 whereas the V8 from a Rover P5b is in a higher state of tune.
The "best" was from a Rover SD1 coupled with the LT77 5 speed gearbox from a donor car and there were plenty of SD1's in dismantlers yards in the early 1990s.
The "ultimate" standard V8 would have been a fuel injected engine from a Vitesse with the twin plenum chambers..
I note the wire wheels. These were not available even as an option on "Factory" MGBGTV8s and not really advisable on V8 engined MGBs. The first V8 cars by Ken Costello often had wire wheels however.
It's not a kit car but according the advert a properly engineered conversion. Pricey though, a MGRV8 would be a better buy in my view. _________________ Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet |
BigJohn
Posted: Wed Aug 10, 2016 7:45 pm Post subject: |
| But which bit is 1972? If I bought a car to build a hot rod, and changed the body shell, then the running gear, what bit would retain the original reg number? It carries a reg number from a tax free MG B, and it appears none of it is older than 1992. It seems to be a bitsa clean sheet build, all be it with new parts, not a conversion. |
Ellis
Posted: Wed Aug 10, 2016 8:03 pm Post subject: |
| BigJohn wrote: | | But which bit is 1972? |
Probably none of it!
I referred to a friend's rebuild onto a new roadster bodyshell and he did the job properly after liaising with the local Vehicle Registration office. They allowed him to retain the registration number and chassis plate from the MGBGTV8.
As a former Vehicle Inspector/Examiner you know better than I do that it was on a "points" system - original axles, brakes, steering column, steering rack and pinion gearbox and so on. A gearbox counted more than an engine.
As the advertised car was a reshell the "restorers" probably did not liaise with the LVRO and only advised of the engine change. I don't even know if "like for like" bodyshells had to be notified.
Same thing as with rebodied "E" Types. There are lots of roadsters with coupe chassis plates and numbers.
Shouldn't be, but it happens! _________________ Starting Handle Expert
BigJohn
Posted: Wed Aug 10, 2016 9:00 pm Post subject: |
Sad but true, I put my question car past a couple of my friends who are MG B owners and their replies were not suitable for an open forum of this quality! |
