trampintransit
Posted: Tue Nov 29, 2016 11:06 pm Post subject: Blasting steel wheels..? |
Is sand blasting too aggressive for 1940's steel spoked wheels? _________________ '60 Armstrong Siddeley Star Sapphire
'80 Reliant Scimitar
Posted: Sat Dec 03, 2016 9:07 pm Post subject: |
When I first got my car on the road I had the wheels sand blasted and respoked.
This proved to be an interesting learning exercise.
1. This taught me that only heavy duty inner tubes are any good.
2. It taught me how to repair punctures by the roadside (since the frequency with which I got punctures tended to exceed one puncture per journey.)
3. It taught me that blasting sand gets into the little drain holes in the rolled edges of the wheel rims and then manages to make its way in between tyre and tube. (...and then punctures standard weight inner tubes.)
Joined: 16 Oct 2008 Posts: 1206 Location: Upper Swan, Western Australia
Posted: Sun Dec 04, 2016 3:17 am Post subject: |
I had my Austin Seven steel spoked wheels sandblasted as a prelude to powder coating back in 2006 and have had no problems at all regarding punctures. I am using motorcycle tubes and have found them trouble free. However, the Seven is obviously a very lightweight car and I only run the tyres at 20psi.
Keith _________________ 1926 Chrysler 60 tourer (100 years old! - a genuine antique!)
1950 Austin A40 tourer
1999 BMW Z3
Posted: Sun Dec 04, 2016 11:57 am Post subject: |
| Look at it this way. If the wheels are past it then it's much better to find that out now through blast cleaning than having a brown trouser moment later on when one or more of them fails while out on the road. |
Joined: 25 May 2011 Posts: 2885 Location: South Cheshire
Posted: Sun Dec 04, 2016 7:52 pm Post subject: |
| Might some form of acid-based rust removal be better in terms of not leaving a load of blast media floating around for ages? |
trampintransit
Posted: Mon Dec 05, 2016 9:36 pm Post subject: |
Bitumen Boy .. They are so bad I'm concerned about physical deterioration. Just thinking that sand may cause too much pitting to leave a good finish for paint, or damage the spoke threads .
Hadn't thought about Peter's issue about media being caught in the wheel
Soda blasting might be a better option. _________________ '60 Armstrong Siddeley Star Sapphire
