RogerB
Joined: 18 Dec 2014 Posts: 177 Location: Suffolk Coastal. U.K.
Posted: Sat Jan 14, 2017 6:35 pm Post subject: 'Ridemaster' variable-rate Spring Control |
In the 1955 October 26th edition of the 'Motor' magazine Toledo Woodhead advertised the Ridemaster variable-rate spring control...'a tonic for tired springs'.
Basically it was a double 'L' shaped bracket fixed to the rear cantilever spring just above the rear axle; from the flat 'L' bracket (above the cantilever spring) a coil spring was anchored to the flat of the 'L' then onto an adjustable 'U' bolt linked to the cantilever spring anchorage on the body- work.
To adjust the sagging effect of the original springs, the nuts on the U bolts were tightened until the correct ride height was achieved thus replacing the need to buy new rear springs.
My questions are-
Did any one ever fit the Ridemaster to their cars and were they effective?
Has any one a copy of the Toledo Woodhead brochure R3?
Are there any around today?
Rogerb. |
Joined: 23 Nov 2007 Posts: 4874 Location: Swindon, Wilts.
Posted: Sat Jan 14, 2017 7:02 pm Post subject: |
Was it something like this?
https://activesuspension.com/ _________________ Bristols should always come in pairs.
RogerB
Posted: Mon Jan 16, 2017 5:53 pm Post subject: |
Yes, It was something like that, but, perhaps not as sophisticated.....
The 1950's ad. showed a more basic way of anchoring the Ridemaster to the rear axle...
I still feel that there a market for it in the UK with all our sagging cantilever springs (and other bits....!)
Rogerb |
Posted: Mon Jan 16, 2017 6:57 pm Post subject: |
With so many cars now having coil springs they use the rubber inserts in the coils, but another answer for leaf springs used to be these.
http://timbren.com/timbren-ses/
I know they are marketed for loads and towing but would they also do the job you want them for? _________________ Bristols should always come in pairs.
RogerB
Posted: Tue Jan 17, 2017 5:32 pm Post subject: |
How ell do I remember the AEON rubbers inserts; I seem to recall using them on my 'rally prepared' Standard 10......
Rogerb |
