trampintransit
Posted: Wed Jan 04, 2017 11:20 pm Post subject: ATF... |
...So the manual says Shell Donax T6 / Castrol TQ / EssoAutomaticTransmission 55 / Energol ATF type A ...
What's the modern equivalent of that? Will Dexron 11/111 be ok?
It's for a BG box in an Armstron Sideley Star Sapphire? _________________ '60 Armstrong Siddeley Star Sapphire
'80 Reliant Scimitar
'47 Jaguar MKIV --- in bits!!!! |
Posted: Thu Jan 05, 2017 1:38 pm Post subject: |
There was a similar discussion on here back in April 2009, but I reckon that that was pretty inconclusive. Personally I would put a call in to Millers or similar who have a significant interest in classic oils and ask their advice |
Posted: Thu Jan 05, 2017 2:39 pm Post subject: |
PAUL BEAUMONT wrote: | There was a similar discussion on here back in April 2009, but I reckon that that was pretty inconclusive. Personally I would put a call in to Millers or similar who have a significant interest in classic oils and ask their advice |
Some sound advice from Paul. Many of the postings on OCC reveal manufacturers and specialists as an under used source of specialist information.
Posting informative replies with due acknowledgement may be useful to other OCC members. |
V8 Nutter
Posted: Thu Jan 05, 2017 8:27 pm Post subject: |
In American cars type A has been replaced by Dextron. Dextron II should be O.K. Dextron III is more suited to heavy duty applications, but as the others have said it always best to check with a specialist |
Joined: 26 Jan 2012 Posts: 1740 Location: Above the snow line in old Monmouthshire
Posted: Thu Jan 05, 2017 9:04 pm Post subject: |
V8 Nutter wrote: | Dextron II should be O.K. (...) |
But it wasn't too common when I was looking for some about 8-10 years ago, so I suspect you may struggle to find it now. |
trampintransit
Posted: Sat Jan 07, 2017 1:13 am Post subject: |
I've got an unopened cntainer of Comma AQM mineral Dexron 11 / 11D .... I've emailed Aylesbury classic oils to ask him .....I'll let you know. _________________ '60 Armstrong Siddeley Star Sapphire
![](images/avatars/177567476555340a6bca317.jpg)
V8 Nutter
Posted: Sat Jan 07, 2017 3:59 pm Post subject: |
Useless information for you. The original Type A atf was phased out because one of it's main ingredients was whale oil. |
Posted: Sat Jan 07, 2017 6:06 pm Post subject: |
V8 Nutter wrote: | Useless information for you. The original Type A atf was phased out because one of it's main ingredients was whale oil. |
When I was at school, late 50's, we did projects about whaling and whale factory ships. |
ajlelectronics
![](images/avatars/212707851050976b3baa881.jpg)
Posted: Sat Jan 07, 2017 6:25 pm Post subject: |
Dextron III is backwardly compatible with the two previous versions. However, many older gearboxes tended to use mineral type F/G AQF, examples being the Ford C3 and Borg Warner 35 as fitted to UK Fords etc.
Therefore I would want to be certain as using Dextron in a type F/G box would be disastrous. _________________ Evans Waterless Coolants
Sat TV / Aerial systems etc: http://www.ajlelectronics.co.uk |
trampintransit
Posted: Thu Feb 16, 2017 10:48 am Post subject: |
It's a Borg Warner DG... The consensus seems to be dextron ll is correct oil. _________________ '60 Armstrong Siddeley Star Sapphire
