Ellis
Posted: Sun May 08, 2016 11:13 pm Post subject: When did you last use a starting handle? |
[im g]
The first car I started with a starting handle was a four day old Renault 4 in the Spring of 1971. The battery wasn't flat or any fault with the car, I just wanted to do it!
The second time was my 1967 Ford Escort van when I embarrassingly put the starting handle straight through the bottom of the radiator. I have written of this before and need no further reminding.
I remember as a child seeing many people using starting handles especially in winter. Mr Hassell, down the road would use nothing else to start his 100E Anglia at any time of the year.
Interesting it may have been but I also remember one Forestry Commission employee breaking most of his right hand teeth while starting a Bedford CA van. The van started but the driver was not quick enough in withdrawing the handle and it whacked his face.
Try explaining the need or use of one to anybody under the age of 40 and you feel like a dinosaur.
What memories do you have of these relics of a bygone age?
[/img] _________________ Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet |
goneps
Posted: Mon May 09, 2016 1:18 am Post subject: |
Not that long ago, actually, while helping a friend to start his recalcitrant Morris Eight—the handle's a useful tool for finding TDC when setting timing.
Long ago, in South Africa, my parter's family owned three examples of the Renault AX. On one occasion her father asked me to crank the one he was driving, but the bl**dy thing backfired and whacked my forehead on the coal scuttle bonnet. Fortunately my skull proved tougher than a Renault bonnet, in which it left a small dent.
Richard |
Joined: 16 Oct 2008 Posts: 1165 Location: Upper Swan, Western Australia
Posted: Mon May 09, 2016 1:57 am Post subject: |
This morning! I regularly turn the Cowley engine over by hand every few weeks while the car is unused.
Keith |
D4B
Posted: Mon May 09, 2016 6:25 am Post subject: |
2 weeks ago.....
I tried to start my series Land Rover on it's starting handle, but haven't got the "knack" I guess. |
Uncle Alec
Posted: Mon May 09, 2016 8:15 am Post subject: |
Every time I check the tappet clearances, ignition timing, or (often overlooked) as an impromptu compression tester. |
Posted: Mon May 09, 2016 10:22 am Post subject: |
As Richard and Uncle Alec have said, an important implement for turning the engine for adjustments.
I had a lot of starting handle experience with Model A and T Fords, in fact I used the handle daily for one whole winter in my A, due to impecuniousness at the time and a nearly deceased battery. In fact towards the end of the season, the battery failed to hold even enough charge for ignition, but undaunted I used a dry six volt torch battery each time.
I managed to scratch up enough funds for a battery in the Spring. _________________ Dane- roverdriver but not a Viking. |
Joined: 20 Aug 2008 Posts: 1468 Location: Netherlands
Posted: Mon May 09, 2016 10:43 am Post subject: |
Early nineties when the battery of my Hillman Imp was toast. I did not have the money to buy a new one for two weeks so those weeks I started the Imp 2 times per day on the handle. _________________ a car stops being fun when it becomes an investment |
Posted: Mon May 09, 2016 10:51 am Post subject: |
If I have a sick battery I prefer to push start a car. Obviously that only applies to a manual and assumes you have a suitable slope handy!.
Just out of curiosity, has there ever been an automatic supplied with a starting handle. I can't think of one and it would be dammed dangerous!
Keith |
Riley Blue
Posted: Mon May 09, 2016 12:14 pm Post subject: |
A year or two ago, most likely after my Riley has been standing for a while however I now have a battery booster gizmo about the size of a thick paperback book that will start it even after it's been sitting for several months.
It's an incredible piece of kit that I was sceptical of at first but I must admit it was by far the best of last Christmas's presents. It doubles up as a power pack for my mobile phone - very useful on events like yesterday's charity drive when an accurate odometer is useful for tulip diagram navigation.
So, for me, unable to do much 'home mechanicing' these days, a starting handle is likely to be a thing of the past. _________________ David
1963 Riley 1.5
1965 Riley 1.5 |
Dipster
Posted: Mon May 09, 2016 2:11 pm Post subject: |
D4B wrote: | 2 weeks ago.....
It is years since I used a staring handle. But the only knack I knew was to be sure the engine was timed correctly and to avoid putting my thumb on its own when holding the handle! If the engine kicked it could be a nasty injury. |
Posted: Mon May 09, 2016 2:32 pm Post subject: |
The last time I one was on a friend's vintage car with magneto ignition. With my SS I need to find a convenient point and give it a rapid quarter turn to get going but this technique was completely useless with the vintage. Unlike the SS you hardly noticed its compressions so it was easy to actually wind up some rotating speed, helped by the heavy flywheel, and with some decent revs on the handle it sprang into life.
V8 Nutter
Posted: Mon May 09, 2016 8:53 pm Post subject: |
Not an automatic, but I remember a story about someone with a Lanchester with a fluid flywheel and a Wilson gear box. They started it on the handle and the car pushed them into the garage wall, but the engine cut out and the only damage was a bent starting handle and badly bruised shins. |
goneps
Posted: Mon May 09, 2016 10:33 pm Post subject: |
Keith D wrote: | If I have a sick battery I prefer to push start a car. Obviously that only applies to a manual and assumes you have a suitable slope handy!.
Keith |
A slight diversion to mention that there have been automatics that could be push started. It simply requires a second hydraulic pump on the output side—70s Mercedes automatics had this feature, but I'd be surprised if there are any now.
Richard |
Posted: Tue May 10, 2016 1:05 am Post subject: |
A friend has a very early T model Ford and when he started it on a cold morning he used to have to jack a rear wheel up before cranking it. When the thing started a rear wheel was revolving! This happened every morning on a ten day rally we were both on. Something to do with the gearbox used on the Fords I believe. I wasn't impressed at all!
Keith |
