Drilling Problem
L5Foye
PostPosted: Mon Apr 03, 2017 2:40 pm    Post subject: Drilling Problem Reply with quote
I am currently restoring a vintage turnip sower. The wooden handles had rotted away and I have managed to make new ones. At each end of the handles were metal caps which had rusted away. I got new caps made from stainless steel. They are a conical shape. I need to drill a hole at the end of each cap. I cannot put the caps in a vice as it would distort them. Can anyone suggest a way of securing the caps which would allow me to drill holes?
PostPosted: Mon Apr 03, 2017 3:50 pm    Post subject: Reply with quote
Maybe a little crude but how about putting a similar taper on a piece of doweling and just holding your end cap on the dowel whilst you grind a hole in the pointy end?
PostPosted: Mon Apr 03, 2017 8:10 pm    Post subject: Re: Drilling Problem Reply with quote
Can you drill from the inside of the cone?
2002 MINI Cooper 'S'
JohnDale
PostPosted: Tue Apr 04, 2017 10:48 am    Post subject: Re: Drilling Problem Reply with quote
Tight(ish) fit blind hole in a piece of wood & as this poster says drill from the inside - very slowly as it's stainless,cheers,JD.
1976 Ford Granada Ghia.
L5Foye
PostPosted: Tue Apr 04, 2017 4:22 pm    Post subject: Reply with quote
Thank you all for the useful hints. Much appreciated.
