spitfirebob
Posted: Thu Mar 30, 2017 5:45 pm Post subject: 7w ten starter pinion spring |
hi all
i have a re-occurring fault on my starter motor
it has had 2 new pinion return springs snap when cranking engine
there is a loud noise/bang when starter engaging which signals a snapped spring
engine has been newly rebuilt so is probably a little tight
would this cause the fault or does problem lie elsewhere?
Bob |
Posted: Thu Mar 30, 2017 9:10 pm Post subject: |
Bob,
Are both of the springs from the same source and do the springs break at the same place? It could be a manufacturing fault. Is this the heavy spring?
spitfirebob
Posted: Fri Mar 31, 2017 8:41 pm Post subject: |
| 47Jag wrote: | Bob,
Hi Art
got both springs from small ford spares
they are the small thin ones that push pinion gear in and out
Bob |
Posted: Fri Mar 31, 2017 10:47 pm Post subject: |
Bob,
This is a standard inertia starter that we are talking about? The light spring, as I see it, is more of a deterrent for the pinion to creep along the screw after the engine has started. The actual pinion return is done when the engine fires and the ring-gear accelerates throwing the pinion back down the screw. This is one of the failings of the inertia style starter. It only takes one cylinder to fire to accomplish the 'throw back'.
Is the spring getting mangled or just snapping? Any pictures?
Posted: Fri Mar 31, 2017 10:48 pm Post subject: |
Bob,
Is the spring getting mangled or just snapping? Ant pictures?
Joined: 14 Oct 2016 Posts: 2136 Location: East Yorkshire
Posted: Sat Apr 01, 2017 9:22 am Post subject: |
I suggest telephoning SmallFordSpares, or go on their website and email a query.
Paul Beck, and his colleagues, are very helpful when it comes to spares not behaving as one would wish.
It is entirely possible there is a quality problem?
I have had problems with one of their rear axle bearing kits, and eventually, between us, things seem 'sorted'. {not useful when the inner bearing sleeve detaches itself from the axle-end sleeve?]
I have to add, I do not know what we old-Ford enthusiasts will do if ever SFS decides to close down..? |
Paul fairall
Posted: Sat Apr 01, 2017 10:52 am Post subject: |
| alastairq wrote: | I suggest telephoning SmallFordSpares, or go on their website and email a query.
I have to add, I do not know what we old-Ford enthusiasts will do if ever SFS decides to close down..? | we will have to hot rod them with more modern running gear  _________________ 1957 ford popular |
spitfirebob
Posted: Sun Apr 02, 2017 2:27 pm Post subject: |
| 47Jag wrote: | Bob,
Here is a pic showing offending spring !
[img] [/img] |
Posted: Sun Apr 02, 2017 9:19 pm Post subject: |
Bob,
I pulled this off the net:-
https://www.smallfordspares.co.uk/m/plates/plate117.gif
I looks like what I would expect to see. Comparing this to your photo the seems to be an anomaly at the end of the armature (No. 11) plus washer (No. 11365). Where on yours it looks to be a solid spacer and a washer and nut. The way it should work is the spring slides over the stepped sleeve and is pushing on the washer 11365. When it engages, the pinion pushes on said washer compressing the spring. So my question is where did you fit the spring on yours? If you fitted it between the pinion gear and the thick spacer the pinion would wind up and tear the spring because there isn't a washer to separate the pinion/spring.
spitfirebob
Posted: Mon Apr 03, 2017 8:21 pm Post subject: |
Hi Art
here is a different view showing washer
i fit spring between washer and thick spacer
[img] [/img] |
spitfirebob
Posted: Mon Apr 03, 2017 8:46 pm Post subject: |
showing how bits are arranged
thick washer next to castle nut is the wrong way round though!!
[img] [/img] |
Posted: Mon Apr 03, 2017 8:51 pm Post subject: |
Bob,
Is the washer next to the nut part of the sleeve to its right? The thick part looks to be part of the Bendix as per the drawing. So is there a washer 11365 inside the thick part of the Bendix? If not that's the problem, if there is it's back to the drawing board
Posted: Mon Apr 03, 2017 8:54 pm Post subject: |
Bob,
The part next to the nut is wrong way round and I don't see the 11365 washer.
Posted: Mon Apr 03, 2017 8:57 pm Post subject: |
Bob,
spitfirebob
Posted: Mon Apr 03, 2017 9:01 pm Post subject: |
[quote="47Jag"]Bob,
Art[/quote
hi Art
the washer is to the right of the spring |
