1935Hillman
Posted: Thu Feb 08, 2018 10:21 am Post subject: Air line fittings |
| I have a problem with my workshop air line. It leaks terribly at the end of the line where the hose connects to the particular tool. All of the tools have the same Sealey male ends but I do wonder if the problem lies with the hose end fitting itself which came with the hose. Anyone with similar experience and general advice on hose and fittings please? I did wonder if the much discussed PCL fittings might be better but when I look online the sealey fittings are generally quite a lot more expensive than PCL (?) |
Joined: 14 Oct 2016 Posts: 2146 Location: East Yorkshire
Posted: Thu Feb 08, 2018 11:02 am Post subject: |
Probably of no help whatsoever, but all my regular-use fittings are of the 'euro' type. There is a certain amount of leakage, but not enough that the wee compressor cannot keep on top of.
An issue I have recently come across concerns teh cheap[er] tools, gauges, etc from ebay.
These are cheap largely because they are made in China...and the Chinese seem to be in a world of their own regarding airline fittings....very little if any are available individually here in the UK.
The Chinese are also reluctant to use BSP threads, which is annoying to say the least. Whereas most threaded fittings easily available in the UK are BSP threaded!!
I have had to make up an adaptor hose [very short] just to enable these bits of kit to connect....the world or airline fittings is indeed a confused one. Thank you Screwfix!
Does PTFE tape adequately seal the threaded portion of an airline fitting? |
Posted: Mon Feb 19, 2018 12:12 am Post subject: |
You mention Sealey. I used to regard this as top quality but when I bought a new Sealey compressor it proved to be far from satisfactory. In fact it was rubbish and within a year ended up on the tip. I now have a wolf compressor and it has been good so far.
I would go for genuine PCL fittings. |
Posted: Mon Feb 19, 2018 10:24 am Post subject: |
PCL may be expensive but in the long run, far less hassle and they last for ages. I have them on all my air tools etc _________________ Rover P2
Posted: Mon Feb 19, 2018 11:30 am Post subject: |
| Phil - Nottingham wrote: | | PCL may be expensive but in the long run, far less hassle and they last for ages. I have them on all my air tools etc |
I agree, once you have your hose fittings sorted it just means spending a couple of quid on a PCL fitting for each tool.
1935Hillman
Posted: Tue Feb 20, 2018 8:25 pm Post subject: |
| Thanks all for comments. Looks like I will go the PCL route and change them all. I don't have that many so not a huge job. |
1935Hillman
Posted: Wed Mar 14, 2018 4:29 pm Post subject: |
| PCL fittings bought on ebay and fitted with much better sealing. |
Clactonguy
Joined: 20 Mar 2018 Posts: 107 Location: clacton on sea
Posted: Thu Apr 05, 2018 7:54 am Post subject: Tape on joints |
| yes PTFE tape. will seal threads on airlines. pcl type connectors are good. I have a mix on. things but will be converting later to same type across all tools. |
