mock up my aquaplane manifolds and twin carbs
PostPosted: Sun Jun 04, 2017 4:21 pm    Post subject: Reply with quote
Don't forget to plug the hole at the end of the manifold's balance pipe section.
Might be an idea to tap it and screw a suitable brass plug inside?
Paul fairall
PostPosted: Sun Jun 04, 2017 5:01 pm    Post subject: Reply with quote
it is tapped bsp I think. Will use for the vacuum wiper
1957 ford popular
PostPosted: Sun Jun 04, 2017 5:08 pm    Post subject: Reply with quote
If it was me. I would blank them off and go for electric wipers.
Trying to balance carbs' and have a vacuum feed out doesn't sound like an ideal situation and I don't suppose I am that far out in thinking the carb/manifold was added to improve performance.
Paul fairall
PostPosted: Sun Jun 04, 2017 5:38 pm    Post subject: Reply with quote
i admit I have been looking at an electric wiper. Thing is, the more refinements are made the more boring a car is to drive. Yesterday I took the popular out to one of our tyre depots to use a socket to remove the steering wheel and line the spokes up. I drove my work vehicle to the lock up, then drove the pop, then the work vehicle home. The pop requires my full attention to drive and the work vehicle feels so comfy, steering is precise etc etc, I've come to the conclusion modern cars are boring get you where you want to go transport that require very little effort. It's no wonder I've only enjoyed riding motorbikes the past thirty years.
1957 ford popular
Kleftiwallah
PostPosted: Sun Jun 04, 2017 6:44 pm    Post subject: Reply with quote
Good afternoon Peter L. The spare parts booklet tells me the orinal carb' was a Solex 26FV (V for vertical positioning).
I've managed to aquire 2 of these and had them profesionally overhauled and jetted. I'll 'ave a bash at setting up what I want to do in a snap.
Cheers, Tony.
Kleftiwallah
PostPosted: Sun Jun 04, 2017 7:17 pm    Post subject: General arangement 'drawing' Reply with quote
Hello again. I hope you can see what I'm trying to do?
Two questions, (1) the choke 'butterfly' is sprung closed. Surely they should be sprung open and only closed when attempting to start from cold?
(2) I've tried to change the linkages so they are both toward each other on the inside. Any suggestions?
Cheers, Tony.
Paul fairall
PostPosted: Mon Jun 05, 2017 10:13 am    Post subject: Reply with quote
No photo Tony
1957 ford popular
PostPosted: Mon Jun 05, 2017 11:18 am    Post subject: Re: General arangement 'drawing' Reply with quote
[img]
/IMG_0240_zpsahchhbja.jpg.html]
[/img]
Cheers, Tony.
Kleftiwallah
PostPosted: Mon Jun 05, 2017 11:22 am    Post subject: Reply with quote
Good morning Peter, I know what has happened, due to me not being used top photobucket I uploaded the snap twice and then went back and deleted the one I had coppied/pasted. If you see what I mean.
Here it is. Two questions, (1) the choke 'butterfly' is sprung closed. Surely they should be sprung open and only closed when attempting to start from cold?
Cheers, Tony.
Paul fairall
PostPosted: Mon Jun 05, 2017 1:34 pm    Post subject: Reply with quote
GARAGE HERMIT wrote:
do you realise you'll have to cut a hole in your bulkhead to get the right hand carb to fit, i've just cut a hole in mine, turn's out you need 2 left carb's, no cutting then,
had a look today and a bit of panel beating to form a depression should be enough.
1957 ford popular
GARAGE HERMIT
PostPosted: Mon Jun 05, 2017 4:07 pm    Post subject: Reply with quote
never thought of that, might work, dont forget you'll need room for your air filter too,
i'm using "pancake" one's,
1957 - 103e - popular,
Paul fairall
PostPosted: Tue Jun 06, 2017 12:17 pm    Post subject: Reply with quote
no filters just bell mouths.
1957 ford popular
Kleftiwallah
PostPosted: Tue Jun 06, 2017 1:15 pm    Post subject: Reply with quote
Peter, are these any good to you?
Cheers, Tony.
GARAGE HERMIT
PostPosted: Wed Jun 07, 2017 8:58 pm    Post subject: Reply with quote
paul, here's a pic, i never cut the semi circle bit at the top, there was already a 2" hole the previous owner drilled,
and an export petrol pump will not fit with a aquplane exhaust manifold, shame,
Paul fairall
PostPosted: Wed Jun 07, 2017 11:13 pm    Post subject: Reply with quote
thanks mate, get an electric pump, mine was only 21.
1957 ford popular
Page 2 of 3
