Miken
Posted: Fri Jun 23, 2017 10:53 pm Post subject: Calormeter |
The calormeter on my Morris does not work.
The needle starts to move as the engine warms but barely gets out of the "cool" sector.
I have put it in a saucepan of boiling water on the stove and nothing further happens.
I have unscrewed and removed the glass lenses, blown out a load of dust and given the needle a poke with my finger to see if that helps but it doesnt.
Has anyone managed to dismantle one of these further and repaired it?
Thanks, Mike
Posted: Fri Jun 23, 2017 11:48 pm Post subject: |
Having looked at this https://www.youtube.com/watch?v=6FnV6zR9h5U
I noticed that the central "yoke" on yours is not in the same place as the video for the same indication.
I would be tempted to split it (4 screws) and see if it can be re-positioned and lubricate it at the same time. using a very light oil and perhaps a feather to apply it.
The operation is apparently a bi-metal strip in the down tube.
There is a discussion on here as well.
http://www.triple-mregister.org/forums/topic.asp?ARCHIVE=true&whichpage=1&TOPIC_ID=11086 _________________ Bristols should always come in pairs.
Miken
Posted: Sat Jun 24, 2017 9:50 pm Post subject: |
Well that was disappointing.
I thought I would have another look at my calorometer.
As I carefully removed the glasses again, it fell apart in my hand.
The old alloy appears to have the tensile strength of a sponge cake.
I easily broke off another piece with my thumb.
On the plus side and with nothing to loose I decided to have another go at making it work.
I filled up from the top, the inside of the stem part with penetrating oil and left it for 30 mins. After tipping it out I warmed the stem of the calormeter up and it now works.
Whoop-dee-f-!**ng-doo!
Joined: 14 Oct 2016 Posts: 2283 Location: East Yorkshire
Posted: Sat Jun 24, 2017 11:17 pm Post subject: |
That's a boooger!
I don't suppose the surround was actually mazac? [Which tends to ''rot'' sometimes, if the original alloy mix was wrong]
However, I fully expect, knowing your skills, to see the next post describing how you turned up a metal case for the gubbins & glasses to sit in?
Good luck with it....  |
Joined: 16 Oct 2008 Posts: 1206 Location: Upper Swan, Western Australia
Posted: Sun Jun 25, 2017 3:27 am Post subject: |
I don't know if it helps much in the UK, but those Calorometers were fitted to wartime and post-war Fordson tractors in Oz. I think that's where mine came from. It may be an avenue to search for another one.
Keith _________________ 1926 Chrysler 60 tourer (100 years old! - a genuine antique!)
1950 Austin A40 tourer
1999 BMW Z3
