AustinTenacious
Posted: Mon Jul 17, 2017 1:48 pm Post subject: Unidentified T-shirt Motif |
Hi, I'm trying to identify the pickup in the motif on the accompanying poor photograph. Is it something like an Austin A55 or larger designation with that grille? Also does anyone ever recall seeing one of these or know who made them?
[img]https://postimg.org/image/sjqpmexqx/[/img]
[not sure if this photo inclusion has worked]
AT
Last edited by AustinTenacious on Mon Jul 17, 2017 10:17 pm; edited 1 time in total |
Posted: Mon Jul 17, 2017 3:14 pm Post subject: |
Hi Austin,
You need to select the link below the top one you used.
AustinTenacious
Posted: Mon Jul 17, 2017 10:16 pm Post subject: |
Thanks for sorting my photo out.
I've looked up those Simcas. There are various styling changes. It does indeed look very much like the P60 type of grille. Higher relative to the headlamps than the A55 so a better match. I found some photos of a few P60s in pickup build. One photo shows a high bulkhead/board that carries the front of a tilt. There are some basic versions - a good match was one on "le parking.be"
AT _________________ Austin Mini MKI 1966 owned since 1983
Spitfire MKIII 1968 owned since 1988 |
Posted: Mon Jul 17, 2017 10:38 pm Post subject: |
Seems a bit odd to me to have a European pick-up on a T shirt, it is more the sort of thing I would expect to see on a rednecks T.
There is no scale so could it be a Yankee truck. _________________ Bristols should always come in pairs.
Posted: Tue Jul 18, 2017 10:33 am Post subject: |
| Penman wrote: | Hi
There is no scale so could it be a Yankee truck. |
You're assuming that it was a conscious decision by someone knowledgeable. More likely someone just googled "old pick-up" or similar and chose the image pretty much at random. |
