103E Roof Join and Wing Joins
ALW Ford Popular
PostPosted: Tue Aug 08, 2017 8:17 pm    Post subject: 103E Roof Join and Wing Joins Reply with quote
Couple of detail questions please?
Where the roof meets the gutter there is clearly a 'dissimilar' metals thing going on with my Pop. Please can someone tell me what the gutter is made of and how the joint (slight groove) should be made up - looks like soft solder and some filler type stuff is present. It also appears, having cleared the corrosion, that there is an overlap join to the roof?? Hard to see how it was made.
Also, need to replace the wing joint piping. I have seen a PVC type, but it looks wrong (in my view!) where can you get the original 'rope' type and can it be over painted / sprayed?
Many thanks
PostPosted: Tue Aug 08, 2017 10:33 pm    Post subject: Reply with quote
The original filling was probably lead.
Have you looked here for wing piping? http://www.woolies-trim.co.uk/c-348-wing-piping.aspx
Art
PostPosted: Wed Aug 09, 2017 9:43 pm    Post subject: Reply with quote
For wing piping I would go with Leathercloth, most trimmers will supply that.
1937 Ford 7w
1937 Hillman 80
1946 ERF C.I.5
1947 Hillman Minx
1955 Hillman Minx Mk8
1950 Commer R541
PostPosted: Thu Aug 10, 2017 10:10 am    Post subject: Reply with quote
Are you a member of the FSOC?
If so, they will have the correct stuff..or know where to get it.
