Miken
Posted: Tue Jul 18, 2017 6:56 pm Post subject: Charging the battery |
When charging the 12v battery on my 27 Morris Cowley (dynastarter and magneto ignition, neg earth) is it necessary to disconnect both (or any) battery leads?
Thanks
Mike |
Posted: Tue Jul 18, 2017 7:22 pm Post subject: |
Hi Mike,
With the car at rest with the engine and ancillaries switched off the battery is not connected to anything and you can safely connect a charger to it.
Miken
Posted: Tue Jul 18, 2017 8:08 pm Post subject: |
Thank you Peter.
MN |
jp928
Posted: Tue Aug 15, 2017 1:36 am Post subject: |
I have a garage queen - doesnt get enough usage - and I keep a trickle charger on it while parked. I used a charge socket like a cigarette lighter socket, with a positive connection centre (2 brass blades that accept a pin like a headphone plug) , and concealed it under the rear licence plate, connected to the battery with a fused line. Its connection is such that I have to walk over it to get to the car, so I dont forget to remove it. With a direct battery connection I can isolate the battery from the rest of the car if necessary to do work, but still leave the charger connected.
Like this plug, and socket to suit, with a cap.
http://www.arindustrialsupplies.com.au/narva-thermoplastic-merit-accessory-plug-82108bl.html
jp 26 Rover 9 |
