Jublybug
Posted: Fri Aug 11, 2017 8:03 pm Post subject: B&B tyre size |
Hello all .
. I'm under way with my wake resto and I've found tyre to arch contact and the wheel was difficult to remove from the wheel arch (although this could of been due to an old jack not lifting as high as needed) so I'm wondering weather the tyres are the correct size ? But what is the correct size? They are 165 r13 fitted from memory . Ive had the shockers off tonight and they feel nice and firm so I don't think its soft suspension that's the issue . .its a b&b chassis that's under the van so any help or info would be great
Thanks again in advance .jim |
christine lowery
Joined: 30 Sep 2009 Posts: 496 Location: wallsend tyne and wear
Posted: Fri Aug 25, 2017 8:11 pm Post subject: |
165/13 sounds about right I have 175/13c on my Royale and she is a ton gross weight
Christine  |
Jublybug
Posted: Sun Aug 27, 2017 1:52 pm Post subject: |
Ok thanks for the reply ,It looks to be old damage and I think the vans had a rough life so might of been well over loaded at some point .
Jim |
