robo0121
Joined: 11 Nov 2013 Posts: 49 Location: Birmingham West Midlands
Posted: Fri May 12, 2017 8:22 pm Post subject: Austin 1300 1972 |
Hi on my Austin 1300 .which is a k reg.1972 with the red strip speedometer.the very far right hand side of the dash .next to the washer plunger.is a red switch..any ideas what its for.thanks in advance |
Posted: Sat May 13, 2017 3:41 pm Post subject: Re: Austin 1300 1972 |
robo0121 wrote: | Hi on my Austin 1300 .which is a k reg.1972 with the red strip speedometer.the very far right hand side of the dash .next to the washer plunger.is a red switch..any ideas what its for.thanks in advance |
If it wasn't the "self destruct" button, may be post a photo. |
Posted: Sat May 13, 2017 5:25 pm Post subject: |
The problem with pressing it to see what it does is that on an oldie it probably doesn't do anything anymore... |
Posted: Sat May 13, 2017 6:28 pm Post subject: |
Bitumen Boy wrote: | The problem with pressing it to see what it does is that on an oldie it probably doesn't do anything anymore... |
Quite likely, but not knowing is nerve wracking  |
Posted: Sat May 13, 2017 9:52 pm Post subject: |
Phone a friend ?
or maybe " Robo - Birmingham . Your starter for 10" |
robo0121
Posted: Sun May 14, 2017 1:15 am Post subject: SWITCH |
Its an on off switch.im pretty certain its an original fitting as the cut out in the dashboard is perfect for it.im pretty sure someone on here has the same vehicle and will instantly identify what it is |
Paul fairall
Posted: Sun May 14, 2017 2:50 pm Post subject: |
Have you tried it? If so and it didn't do anything, then what if anything doesn't work. Do you have a wiring diagram for the car? _________________ 1957 ford popular |
robo0121
Posted: Sun May 14, 2017 3:43 pm Post subject: switch |
i googled austin 1300 which i believe mine is an early mk 3 model as mine doesn't have the fablon dashboard.i was hoping to see a display of the dashboard.but unfortunately.my model wasn't on there |
Posted: Sun May 14, 2017 4:06 pm Post subject: |
Can you take a photo ?... if you have problems uploading, ask, and I am certain someone will take it via e-mail and upload it. |
BigJohn
Posted: Sun May 14, 2017 5:29 pm Post subject: |
If you can see the wiring, compare the colours to the wiring diagram.
(but it being a BL product, that might not provide a definitive answer.....) |
robo0121
Posted: Sun May 14, 2017 5:48 pm Post subject: switch |
I have the car in a garage.next time I'm over there I will photograph the sed switch.till then I might still get an answer |
