Joined: 23 Nov 2007 Posts: 4258 Location: South Cheshire
Posted: Sun Oct 29, 2017 1:40 pm Post subject: De-greasing fluid recomendations |
I need to replace the de-greasing fluid in my parts washer; I need 50L of fluid.
I think the current concoction is a combination of Jizer topped up with heating oil..
What fluids have members found that work well and don't need frequent changing.
Ta Dave[/b] |
Kleftiwallah
Posted: Sun Oct 29, 2017 2:46 pm Post subject: |
I would suggest Paraffin (or is it Parrafin)?
Cheers, Tony.  _________________ It may work in practice, but not necessarily in theory! |
Posted: Sun Oct 29, 2017 2:48 pm Post subject: |
I prefer paraffin with or without Derv _________________ Rover P2
troutrunner
Joined: 03 Dec 2012 Posts: 185 Location: South Lincolnshire
Posted: Sun Oct 29, 2017 3:02 pm Post subject: |
I bought mine off of eBay, it is just a generic one I believe, it does what it says on the tin (well plastic drum actually) and I seem to recall about £20 for 25ltr. delivered  _________________ Paul
1937 Ford Model Y.
1939 Austin 10.
1955 Austin A30.
1958 Ford 300E van.
1961 Austin A40.
1964 Wolseley Hornet.
1965 Series2a Land Rover.
1968 Wolseley Hornet.
1994 Peugeot 405 Est. 2of.
Nil illegitimi Carborundum |
Posted: Tue Oct 31, 2017 3:18 pm Post subject: |
| We used paraffin in my Dad's garage in the 50s and I still use it. Cheap and cheerful, and damned efficient. |
petelang
Posted: Tue Oct 31, 2017 4:56 pm Post subject: |
I have used Morris Oils "Lydian" degreaser. It's powerful stuff but does stink a bit and can be washed off with water. I also used it NEST in a parts washer but that was probably not a good idea as it melted the plastic housed electric pump!
Sprayed on with a pump up garden sprayer bottle, left to soak for a bit, it seems to pretty well degrease anything.
https://www.morrislubricants.co.uk/lydian-degreasing-fluid.html
Peter |
