Thread cutting phenomenon
Kleftiwallah
PostPosted: Fri Nov 10, 2017 1:14 pm    Post subject: Thread cutting phenomenon Reply with quote
I'm in the shed making a new brake rod from 5/16 th mild steel cutting a B.S.F. thread 5 inches long. The first two inches are spot on, but then the thread seems to form a long amplitude helix (although the threads along the whole length are acceptable).
Now, why is this happening (or has happened)?Question
Over to you knowledgeable people. Cheers, Tony.
It may work in practice, but not necessarily in theory!
PostPosted: Fri Nov 10, 2017 1:21 pm    Post subject: Reply with quote
Stretched!
Peter Question
Kleftiwallah
PostPosted: Fri Nov 10, 2017 1:26 pm    Post subject: Reply with quote
Nope, not stretched. Still the original length.
Cheers, Tony.
PostPosted: Fri Nov 10, 2017 1:45 pm    Post subject: Reply with quote
Could it be that the rod is twisting due to the resistance to the die cutting and in so doing reduces in diameter slightly Question
Art
PostPosted: Fri Nov 10, 2017 3:41 pm    Post subject: Reply with quote
Whilst I admit to inexperience when it comes to thread-cutting, a chum has suggested the thread form has 'stretched' because the thread itself was being cut, 'too quickly'...the die apparently can march down the rod improperly if turned too fast?
PostPosted: Fri Nov 10, 2017 6:19 pm    Post subject: Reply with quote
When I cut male threads on the lathe with a die I turn everything by hand, I'm sure someone will correct me , but I cut male threads with the die open wide, and them mak a couple of passes with it closed.
Uncle Alec
PostPosted: Fri Nov 10, 2017 10:03 pm    Post subject: Reply with quote
Me too Dave. I convert surplus Riley RM radiator steady rods into clutch rods by doing just what you say; expand the die as far as by sending the V-pointed grub screw way in, then another run with it out and the locating grub screws tight in.
Kenham
PostPosted: Sat Nov 11, 2017 9:00 am    Post subject: Reply with quote
I find it easier to turn threads with the lathe , quite a satisfying job I find. All well and good if you have a lathe of course. As to the original question yes to much too soon I suspect and turning the rod instead of cutting properly.
Kleftiwallah
PostPosted: Sat Nov 11, 2017 11:10 am    Post subject: Reply with quote
Thanks to all your knowledgeable answers,
I think 47jag has hit the nail on the head. I did have the rod projecting quite a way up from the vice jaws. I cut another length with only 1 1/2 " out of the vice at any time dieing down until I barked my knuckles only then lifting the rod higher by the same amount and the thread is spot on all the way down..
Take a sweety out of the jar 47jag!
Cheers, Tony
PostPosted: Sun Dec 24, 2017 6:16 pm    Post subject: Reply with quote
Forgive me for casting aspersions but you say you are making up brake rods? . That sounds like you are using some pretty crummy steel to me. I would want something a bit tougher if it was my life depending on it. Shocked
