LED instrument lighting.
Kleftiwallah
PostPosted: Mon Dec 11, 2017 5:08 pm    Post subject: LED instrument lighting. Reply with quote
Good afternoon peoples,
can anyone out there tell me about fitting LED instrument lighting? I'll need about 6 LEDs, what other components do I need (apart from a 12 V battery).
I have constructed a box to enclose the rear of the instruments and need them lighting from within.
I know apsolutely nothing about LEDs.Confused
Looking forward to your replies. Cheers, Tony. Question
alanb
PostPosted: Mon Dec 11, 2017 5:59 pm    Post subject: Reply with quote
Didn't you start this topic back in June/July ? I recall there being several answers then, or were they not of any use?
old tourer
Morris 8 two seater
Kleftiwallah
PostPosted: Mon Dec 11, 2017 7:40 pm    Post subject: Reply with quote
Yes there were a couple of replies but alas, they were all a tad technical.
I'm hoping someone can come up with a "Janet & John" reply Embarassed
There seems to be some sort of starter component required which I do not understand. I'm going to try and ask the technical staff at R.S. for help in the morning.
Cheers, Tony.
PostPosted: Mon Dec 11, 2017 8:10 pm    Post subject: Reply with quote
Some sort of resistor because LED's don't 'do' full voltage?
PostPosted: Mon Dec 11, 2017 8:13 pm    Post subject: Reply with quote
http://www.nostalgiatech.co.uk/LED%20Lighting.htm
Kleftiwallah
PostPosted: Tue Dec 12, 2017 12:55 pm    Post subject: Reply with quote
Good morning Peter, many thanks for that, I've just sent this Peter an email pleading for help.
Cheers, Tony.
alanb
PostPosted: Tue Dec 12, 2017 3:08 pm    Post subject: Reply with quote
This company do a wide range of led lighting and have alway been very helpful in my dealings with them. http://www.dynamoregulatorconversions.com/
old tourer
Morris 8 two seater
PostPosted: Tue Dec 12, 2017 3:46 pm    Post subject: Reply with quote
Cheers, Tony.
They're one and the same person I think Wink
alanb
PostPosted: Tue Dec 12, 2017 3:53 pm    Post subject: Reply with quote
http://www.dynamoregulatorconversions.com/ Are a Lincoln based company run by Pete Jury. Perhaps I missed a link somewhere?
old tourer
Morris 8 two seater
PostPosted: Tue Dec 12, 2017 5:31 pm    Post subject: Reply with quote
I have responded to Tony's private messages to me and included alanb's link.
(I'm not Pete Jury.)
jp928
PostPosted: Fri Dec 15, 2017 6:15 am    Post subject: Reply with quote
LEDs are readily available, I have many in 6V for my 26 Rover. Note also that they are polarity sensitive - get it wrong, no light. Establish which is +ve lead with a 9v battery, and mark it. Also note that SOME , but not all, wedge type leds come with their leads folded back over the pointy end of the wedge such that in some sockets you have an immediate short circuit. If fitting to an older car wedge sockets are unlikely.
jp 26 Rover 9
winchman
PostPosted: Fri Dec 15, 2017 11:26 am    Post subject: Reply with quote
Ebay has loads for buttons
https://www.ebay.co.uk/itm/10X-Car-T5-286-W1-2W-1LED-Dash-Speedo-Bulbs-Instrument-Lights-Rear-Blue-White/182697545569?hash=item2a899f4f61:m:mGPVAGJmZW1z82JfaYPUVRQ
Just wire them up they run on 12v as the resistor is built on, if you connect them the wrong way around they are protected so just turn them around and they work.
I would drill a small hole and once you have wired up and tested the LED's just glue them in with no nails or silicone, its unlikely they will ever need replacing.
It will come in handy even if you never use it.
