Quiz: what grille?
David Kipling
PostPosted: Tue Jan 09, 2018 9:10 pm    Post subject: Quiz: what grille? Reply with quote
British stock car, circa 1965: grille is from a -----?
http://www.oldstox.com/images/69.%20May%201964%20LE.JPG
The driver had a 437 cu.in. Buick with a hot cam. It did the job!
PostPosted: Tue Jan 09, 2018 11:06 pm    Post subject: Reply with quote
The grill looks like something from the mid 1930s except that most cars of that period had much taller radiators. I suspect that it has been shortened to fit the stock car and so looking for a mass produced item will not reveal anything.
I think the earlier suggestion of a Delahaye 135 grill shortened to fit will be the most likely solution.
David Kipling
PostPosted: Wed Jan 10, 2018 4:02 am    Post subject: Reply with quote
Yes, it's from a 1937 Delahaye saloon: bonnet, sides and grille, but (typically) someone has nicked the nice enamel badge from its plate.
BTW: I clumsily posted this (I think) in two forums, so no doubt you refer to "the other" posting. Cheers.
PostPosted: Wed Jan 10, 2018 9:25 am    Post subject: Reply with quote
I was refering to your previous posting on this forum from 7 years ago!
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=10164&highlight=
David Kipling
PostPosted: Wed Jan 10, 2018 7:00 pm    Post subject: Reply with quote
OMG! as my daughter says. What a memory you have, and what a failed memory I have Wink
