Best glue for Carpet to Plywood
Kleftiwallah
PostPosted: Thu Feb 01, 2018 8:50 pm    Post subject: Best glue for Carpet to Plywood Reply with quote
The title says it all.
It's between P.V.A. and Evo Stik 258. Unless you knowledgeable persons know of something better?
Cheers, Tony Rolling Eyes
PostPosted: Fri Feb 02, 2018 11:38 am    Post subject: Reply with quote
If you can be sure of getting it positioned right first time I would tend to go with the Evo Stik. Depending on the type of carpet good old Copydex may also be suitable, though the problem with Copydex is that it's rather smelly and the smell can linger for a while. Evo Stik won't smell once fully cured. I would tend to avoid PVA, it can cause fabrics to wrinkle as it dries and I suspect carpet may suffer with the same problem.
Kleftiwallah
PostPosted: Fri Feb 02, 2018 2:29 pm    Post subject: Reply with quote
Thanks Bitumen Boy,
I've priced Evo Stik at Screwfix. On the webpage it says:-
You must be over the age of 18 to purchase this product.
As I'm 68 (and look it) I think I'll still take along some form of identification just in case some Mucteow wants to play games.
Cheers, Tony.
PostPosted: Fri Feb 02, 2018 3:27 pm    Post subject: Reply with quote
Kleftiwallah wrote:
Thanks Bitumen Boy,
Cheers, Tony.
I'd take some ID for sure. My dad was once asked for it to buy booze in a local supermarket, not sure how old he was at the time but definitely over 65. Even someone in the queue behind told the till girl she was being silly but it made no difference!
PostPosted: Fri Feb 02, 2018 3:43 pm    Post subject: Reply with quote
3M do a good spray adhesive. You get it cheaper than this.
https://www.ebay.co.uk/itm/3M-77-Spray-Adhesive-500-ml-UK-Seller-new-price-Free-shipping-/261212682527
PostPosted: Fri Feb 02, 2018 4:22 pm    Post subject: Reply with quote
Try WOOLIES. https://www.woolies-trim.co.uk/product/1504/aerosol-adhesive. £4.34 plus delivery
ART
