Lucas dynamo
bsa500
PostPosted: Sun Apr 15, 2018 10:47 pm    Post subject: Lucas dynamo Reply with quote
What are the differences between the c40 and c45 dynamos. I can find lots of parts and info for the 40 but very little for the 45
PostPosted: Mon Apr 16, 2018 9:46 am    Post subject: Reply with quote
basically half an inch"
C40 is 4" diameter C45 4.5", I think the outputs are slightly different C40 22A, C45 25A
bsa500
PostPosted: Mon Apr 16, 2018 11:14 am    Post subject: Reply with quote
Thanks how does the 45 gain the extra amps. As there is no specific C45 could or armature I can find?
PostPosted: Mon Apr 16, 2018 2:07 pm    Post subject: Reply with quote
Take a look at this Lucas doc:
http://www.mg-cars.org.uk/imgytr/pdf/lucascourse4.pdf
PostPosted: Mon Apr 16, 2018 2:25 pm    Post subject: Reply with quote
You can get 30A easily out of a C45 if the correct regulator is used. The windings are more substantial and its extra bulk allows more cooling. Straight fit too
Rover P2
Morris Mini Traveller Mk2
