Trim Fastenings?
A62tim
PostPosted: Thu May 17, 2018 11:06 am    Post subject: Trim Fastenings? Reply with quote
Does anyone know where I can get fastenings to fix the exterior trim to my Cheltenham Kudu?
https://www.dropbox.com/s/oby4326v13p9lao/20180517_101953.jpg?dl=0
Not sure if the link works here!
Thanks
Tim
old iron
PostPosted: Thu May 17, 2018 5:36 pm    Post subject: Reply with quote
Link didn’t work for me, however if it proves to be an elusive part you could consider using the 3D printing available now. Most stuff can be replicated to good working standard.
PostPosted: Fri May 18, 2018 8:42 am    Post subject: Reply with quote
Try Howard at Bresco, very helpful person
https://bresco.com/
Kev
PostPosted: Fri May 18, 2018 10:23 am    Post subject: Reply with quote
For a reasonable quantity, that part wouldn't be too hard to make a mould for. Mould-making silicone and casting resin isn't that expensive to buy and I'm having some fun experimenting casting bits for my car.
Otherwise though Bresco is always worth a look, as Kevin said. Some of the clips on this page look as if they might do the job, depending on dimensions of course: https://bresco.com/acatalog/Moulding_Clips_-_Plastic.html
A62tim
PostPosted: Sun May 20, 2018 7:04 pm    Post subject: Trim Fastenings Reply with quote
Thank you for the suggestions, I have managed to locate some second hand ones.
