Wiring rear lights.
PostPosted: Sun Jun 03, 2018 1:47 pm    Post subject: Wiring rear lights. Reply with quote
Has anyone any experience of wiring up rear lights and indicators from scratch?
My lorry is a 12v system and has no wiring at all for the rear.
Any help or tips would be appreciated?
PostPosted: Sun Jun 03, 2018 4:54 pm    Post subject: Reply with quote
Just have a look at any 50s or 60s (simple) car wiring diagram. It shows a very simple path to follow.
Take the feeds from the headlamp and indicator switches.
PostPosted: Sun Jun 03, 2018 5:45 pm    Post subject: Reply with quote
I can take the headlight feeds but its never had indicators fitted so I will fit a period flasher unit and switch.
PostPosted: Sun Jun 03, 2018 9:14 pm    Post subject: Reply with quote
Look at a Morris Minor Wiring diagram, if the lorry is pre 1960 you could even have flashing stop lamps as the MM S2 had Smile
PostPosted: Mon Jun 04, 2018 9:05 am    Post subject: Reply with quote
It is a straightforward task - use a period simple diagram as above. Do keep to the correct colour codes as it does help others later to sort things out
Rover P2
Morris Mini Traveller Mk2
PostPosted: Fri Jun 15, 2018 10:06 am    Post subject: Reply with quote
I have now set up a period dash switch, 2 pin flasher and wired up two period tail indicators. A little bit of fiddling and correcting earth's etc and having to re-solder the wires into one of the NOS lights and when all connected I have working rear indicators!
I have connected them on short feeds to the back of the chassis just to prove they operate, now I need to feed them up the chassis and up into the main control panel in the cab.
