Saturday morning chefs.
Kleftiwallah
PostPosted: Wed Oct 03, 2018 1:53 pm    Post subject: Saturday morning chefs. Reply with quote
Good afternoon everyone, luvely October day aint it?
Do the blowtorches so beloved by the Saturday morning chefs produce sufficient heat to braize/braze small items?
I needed a long small diam' bolt but didn't have one long enough so I braized 2 end to end and cut off a head. It did the trick but the flame was a tad large!
Over to you members for your knowledgeable thoughts.
Cheers, Tony. Smile
PostPosted: Wed Oct 03, 2018 2:55 pm    Post subject: Reply with quote
I would have thought the temp would be the same because they use butane same as the DIY ones. The temp is regulated by exactly where in the flame you position the piece you're working on.
The hottest part is I understand at the tip of the inner cone of the flame.
Kleftiwallah
PostPosted: Wed Oct 03, 2018 6:16 pm    Post subject: Reply with quote
Thanks for that reply Penman,
the hottest part of the flame i remember from school (soooo long ago). The flame from the blowtorch I have (butane) is very 'confused.
I'll look out for a 'cheffie job'.
Cheers, Tony.
PostPosted: Wed Oct 03, 2018 6:49 pm    Post subject: Reply with quote
Hi Tony
My hobby blow torch has three different heads a narrow one, a solder tip one, and a wide one which also has a flattened flare end available; which gives a flame like the one you describe.
I don't know which are dearest but don't forget the DIY ones are most likely to have a number of nozzles rather than just one.
Have you checked whether you can get other, different nozzles to fit yours?
Kleftiwallah
PostPosted: Fri Oct 05, 2018 9:42 am    Post subject: Reply with quote
Good morning Penman,
could you tell me from where you bought your hobby torch? It sounds just the job.
Cheers, Tony.
PostPosted: Fri Oct 05, 2018 7:55 pm    Post subject: Reply with quote
I've had it a long time.
It is a Tamar LG80
This is the basic set plus the flared end.
https://www.ebay.co.uk/itm/Taymar-LG80-Butane-Blowlamp/323481979543?hash=item4b51074a97:g:V74AAOSw6EZbteDR
This is the extra fittings.
https://www.ebay.co.uk/itm/Vintage-Taymar-Gas-Burner-Set-B7-34-Blowlamp-Set-In-Original-Box/263942393747?hash=item3d74314f93:g:YdwAAOSwyCZbfAcH
This set has everything except a gas cannister,
https://www.ebay.co.uk/itm/Vintage-Taymar-Butane-Gas-Blowlamp-Set/352474756498?hash=item521121f592:g:qlYAAOSwS2FbeIZQ
and is cheaper than the other 2 combined and it is probably best not to use the mails for transporting gas any way it uses the type that looks liike an aerosol can and has a screw fitting for the burner to attach to.
Which most DIY stores/Hardware shops carry and you don't have to buy multiple cans like the advert below
https://www.ebay.co.uk/itm/PACK-X-12-Go-System-Butane-Propane-Mix-Gas-277g-blowlamp-screw-thread-no-2277/172486597313?epid=1561566233&hash=item2829009ac1:g:f2wAAOSw241Yej6X
