Motorcraft starter motor relay [solenoid]
PostPosted: Wed Oct 31, 2018 4:53 pm    Post subject: Motorcraft starter motor relay [solenoid] Reply with quote
Hi...a question. I have just obtained a Motorcraft starter motor relay [solenoid].....genuine item, used by Ford {USA]..... as a stand-by to replace what I think is failing item on my '67 Mustang.
[Sage advice is to avoid cheap copies, go for 'real thing']
Anyway, it arrived, and was inspected...a good quality of construction..hopefully with decent internals.
However, it has one oddity.
On the outer end cover [underneath which, lies the big solenoid contact]....there is [offset from centre] a tiny felt pad held in place firmly.
Now, my first thought was, an oil pad to lubricate the moving solenoid shaft....but I'm now a bit uncertain.
The one on the car has no such item....and isn't a motorcraft product anyway.
I have never seen a lube pad on any other type of starter solenoid I've got, or come across.
I've searched and pinched a piccy off Gooogle...the only one I can find showing outer end. the felt pad can be clearly seen.
Do I dribble a few drops of 3-in-1 on it? Or do I dribble contact cleaner on it?
Does anybody know for definite, please?
PostPosted: Wed Oct 31, 2018 10:11 pm    Post subject: Reply with quote
Hi Alastair. My immediate and gut reaction (accepting family viewing) is to contact Motorola and ask (WTF) is that beautifully placed, intrinsically required piece of non-metallic substance oozing from an aperture.
