Kleftiwallah
Posted: Sun Nov 04, 2018 1:28 pm Post subject: Gurt big fuse. |
On the firewall of the BSA was a great big fuse, two sprung posts with a 'paxalin' looking blade between with fuse wire across the posts, It is under a black plastic cover held in place by a spring clip.
Does anyone recognise this description. (1) Is it essential, (2) What is the correct rating and (3) where doss it fit in the circuitry?
If anyone wants a snap of it, please email me and I'll try and send it.
Cheers, Tony. _________________ It may work in practice, but not necessarily in theory! |
Posted: Sun Nov 04, 2018 3:40 pm Post subject: |
Big is relative so a pic is required. What does it supply? _________________ Rover P2
Kleftiwallah
Posted: Sun Nov 04, 2018 3:52 pm Post subject: |
Good afternoon Phil,
that is the reason for my detailed description, I cannot figure out how to put snaps on these posts (I have one ready).
I have no idea what it supplies or protects, that's my reason for asking.
Perhaps Paul Fairall could explain in layman's terms?
Posted: Sun Nov 04, 2018 6:02 pm Post subject: |
It sounds like it might be a knife switch rather than a fuse but perhaps it wasn't making good contact and someone has simply wired it shut with wire.
Kleftiwallah
Posted: Tue Nov 06, 2018 9:19 pm Post subject: |
Good evening Peter, by knife switch, do you mean a blade fixed at one side and pivoted to make contact. If so no it aint. The paxalin 'blade' is inserted just like a spade fuse.
I do wish I could send a snap...
Posted: Tue Nov 06, 2018 10:20 pm Post subject: |
Tony,
What you describe sounds like the mains box fuses in my house. You have a black Bakelite piece about 1 1/2” long with a blade at each end. Between the blades along a longitudinal hole runs a bit of fuse wire connecting the blades. We’ll call that part the male and the female would be where the wires are connected. A PO has probably been a spark and used what was to hand to make up a ‘master fuse’. Does that sound familiar?
Art |
Posted: Tue Nov 06, 2018 10:22 pm Post subject: |
Tony,
Art |
Posted: Thu Nov 08, 2018 6:59 pm Post subject: |
Actually, I thought it seemed to the type of mains fuse seen 100 years ago and obsolete by the 70's.
47JAG - if you have them in your home I suggest an urgent safety electrical inspection. These fuses can spray hot molten metal around when they "Blow" _________________ Rover P2
Posted: Thu Nov 08, 2018 7:12 pm Post subject: |
Phil,
These are mid-60s vintage. While your point may be valid since all fuses ‘spray hot molten metal’ when they blow there is a containment capability in these in that the fusewire runs through an asbestos sleeve and is enclosed inside the fuse holder. The next owner can rewire the box.
Art |
Kleftiwallah
Posted: Fri Nov 09, 2018 1:16 pm Post subject: |
Interesting communications all, 47jag, we also still have the type of fuse in our domicile as you describe. Must get round to having them all replaced with circuit breakers soon.
Have you tried to find fuse wire???
Posted: Fri Nov 09, 2018 3:42 pm Post subject: |
Kleftiwallah wrote: | ............ Have you tried to find fuse wire???
Cheers, Tony. |
Tony
The ironmongers in the Bath Guildhall Market has plentiful supplies of fuse wires on little cards.
Not 6d any more, though. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Fri Nov 09, 2018 4:37 pm Post subject: |
At a pinch, a 6 inch nail will do the job...never known to blow!! _________________ Dellow Mk2, 1951 built, reg 1952.
