Can anyone ID this switch please + maybe cross-ref?
greenbeam
PostPosted: Sun Jan 06, 2019 3:25 am    Post subject: Can anyone ID this switch please + maybe cross-ref? Reply with quote
Happy New Year all,
I am working on the instruments and switches for my 1935 Armstrong Siddeley and need to refurbish the headlamp and ignition/starter switches.
Is anyone able to positively ID the Lucas model (and perhaps cross-ref to a more common vehicle)? I haven't found anything that's an exact match from Holden's, Complete Automobilist, etc. The switch has Lucas PLC on it, but it's not a PLC2 or 5/6 etc.
For the headlamp switch, I just need a new face/label. Failing one available to buy, I intend to get some kind of vinyl stick-on label made and stick it over the existing one.
For the ignition/starter switch, I could do the same for the face/label, but I also need to repair the gouged-out key slot. Any advice on tackling that would be very welcome. I have a vague hope that someone is reproducing them (call me an optimist! Smile
Anyhow, photos of the switches for hopeful ID and cross-ref.
Cheers,
Paul.
PS - I desperately owe a progress update on the car, will do that shortly. Great progress made in 2018!
1963 Sunbeam Alpine Series 3
1935 Armstrong Siddeley 17HP Sports Saloon
1935 Armstrong Siddeley 17HP Coachbuilt Saloon
DM
PostPosted: Sun Jan 06, 2019 10:28 am    Post subject: Reply with quote
Possibly Model no SX4-3 type L 2/33 12volts
Looking at the wiring it should not be too hard to fit a modern 3 position switch in place of the bendix switch but you would possibly need to add a remote starter switch.
http://www.da7c.co.uk/History%20Section/LUCAS%20ACHIVE/Lucas%20Instructions%20for%20Electric%20Lighting%20&%20Equipment%20&%20Accessories.pdf
For a new face try your local Trophi engravers, should be a simple job for them to cut and engrave a new one.
petelang
PostPosted: Sun Jan 06, 2019 11:47 pm    Post subject: Reply with quote
Have you tried ASOC Stores? You will be amazed at just what they have. The Startix especially is going to be a Siddeley peculiarity so I'm sure other club members will be able to help.
greenbeam
PostPosted: Mon Jan 07, 2019 12:45 am    Post subject: Reply with quote
I'll try the stores, but not holding my breath for something like this. I don't believe my 17HP has Startix, so this switch must have been swapped in at some point. I'm hoping that a close-up of the ASHT 17HP car will show the correct original switch.
I'd rather stay original than fit a later switch.
Thanks for the ref number though, I'll start googling and see if anything comes up.
Cheers,
Paul.
greenbeam
PostPosted: Mon Jan 07, 2019 4:24 am    Post subject: Reply with quote
I've updated the main thread about the car too: http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?p=165580#165580
PostPosted: Mon Jan 07, 2019 2:32 pm    Post subject: Reply with quote
I had to google Startix....nothing new under the sun, is there? Smile
PostPosted: Mon Jan 07, 2019 9:14 pm    Post subject: Reply with quote
Startix was at least an option on some Triumph models of much the same era, but don't ask me which..!
PostPosted: Mon Jan 07, 2019 11:26 pm    Post subject: Reply with quote
It was fitted to my old neighbour’s Standard 9 (1936 I think).
Art
HRSC_Sam
PostPosted: Sat Feb 08, 2020 8:46 am    Post subject: Reply with quote
From my basic knowledge startix was a automatic starting system on a cars of the late 30s, I’ve seen them on Wolsey, standard, and triumph so must be a item that’s still available but I’ve only seen the on off switch’s never seen one with manual, off and auto
greenbeam
PostPosted: Sun Feb 23, 2020 7:51 am    Post subject: Reply with quote
Thanks for the info everone. I wasn't successful in finding good used or reproduction switches, so set about refurbishing the ones I have. Stripped them down, had the bodies rechromed, and had new vinyl labels made with the same text and font as the originals. The ignition/starter switch had the key slot gouged out, so I had that silver soldered closed, then reformed the key slot before getting it chromed.
I had a sheet of labels made, so if anyone else has similar switches, I have some spare.
Cheers,
Paul.
