Thermostats
PostPosted: Tue Feb 26, 2019 2:22 pm    Post subject: Thermostats Reply with quote
After taking my Commer lorry out for a run up of the engine she boiled up. I want to replace the thermostat but this far I am having trouble.
The Commer 5/7 ton Parts list give the thermostat as 'BGA.5551', I have phoned around my usual helpful contacts and they haven't heard of the number!?!
Does anyone on the forum know of someone to recommend for help finding one?
PostPosted: Tue Feb 26, 2019 3:14 pm    Post subject: Reply with quote
I think that's what I'd call a 'universal' 'stat. It should be readily available in 175 185 or 195 degree versions.
Does it look like this? https://www.amazon.co.uk/BGA-CT5551-Thermostat/dp/B00AN5WUH8
2002 MINI Cooper 'S'
PostPosted: Tue Feb 26, 2019 3:39 pm    Post subject: Reply with quote
No it doesn't look like that, look at he picture below its item 197.
PostPosted: Tue Feb 26, 2019 4:17 pm    Post subject: Reply with quote
Oh!
That's the bellows style - boat engines often used them.
I suspect the later wax-stat style will fit.
(W-S-M at Easter, do you think?)
PostPosted: Wed Feb 27, 2019 7:15 am    Post subject: Reply with quote
I agree that a standard bellows one will probably fit, however a word of caution- while the older units could fail, they would fail 'open' but I do believe that some modern ones can fail 'closed' and that could be disastrous to ones engine.
lowdrag
PostPosted: Wed Feb 27, 2019 7:22 am    Post subject: Reply with quote
That sir, is very true. I had a stock of old bellows stats but stupidly let friends have some over the years and am now down to my last spare which I am guarding preciously. It was all very well stuffing cardboard in front of the radiator to keep the water warm, but if the new ones fail then you're in trouble.
PostPosted: Wed Feb 27, 2019 10:40 am    Post subject: Reply with quote
Do I take it that like normal thermostats it cannot be repaired but has to be replaced?
PostPosted: Thu Feb 28, 2019 1:26 pm    Post subject: Reply with quote
Would be pretty difficult to repair. The bellows type is still available new - but at a cost. I bought one for my TR4 two years ago because at that engine, the bellows type opens up (or closes down) a water port which would not happen with a normal type of thermostat.
I would try a normal thermostat first to see what happens.
PostPosted: Fri Mar 01, 2019 11:56 am    Post subject: Reply with quote
Will a normal AC type thermostat do the same job?
With the bellows type as long as the outer diameter where it seats is the same could I just get any replacement bellows type, I have seen a few on ebay?
PostPosted: Fri Mar 01, 2019 12:12 pm    Post subject: Reply with quote
Yes, I believe so.
I imagine the Commer does not have a pressurized system.
PostPosted: Sun Mar 03, 2019 4:28 pm    Post subject: Reply with quote
After a fight got the thermostat housing off, its very awkward. The thermostat is well seized so obviosly needs replacing.
The problem though is the retaining ring, item 199 in the diagram, is a push fit and hold the thermostat in position. It is rusted solid and seized in place. Plenty of ease it oil applied and will try some heat on it next weekend.
