awaye
Posted: Sun Mar 03, 2019 10:03 am Post subject: hillman imp drive belt alignment |
I am having trouble with the drive belt alignment from water pump pulley to generator and crank pulleys.
When I bought the car the water pump pulley had been welded to the water pump shaft and was out of alignment with the other pulleys ,I have since repaired this but seems to be elsewhere where the problem lays any one any ideas on how to correct this? |
