Joined: 30 Apr 2013 Posts: 4324 Location: The Somerset Levels
Posted: Thu Apr 11, 2019 10:16 am Post subject: Cast Iron Welding |
Does anyone have any experience of using companies to weld/stitch cast iron cracks and fractures?
I have googled and there are a few companies out there who offer services for vintage vehicles. _________________ Various Rootes Vehicles. |
Posted: Thu Apr 11, 2019 1:03 pm Post subject: |
My first quote is back, to do the 2" break on the neck the the housing, £354 ex VAT and postage!?!
I expect it to be expensive but not that expensive! _________________ Various Rootes Vehicles. |
Joined: 20 Aug 2008 Posts: 1509 Location: Netherlands
Posted: Thu Apr 11, 2019 4:24 pm Post subject: |
A competent welder should be able to weld it. You could bring it to my friend who has been doing repairs to cast iron blocks before and would do it much cheaper. Snag is he is in the south of the Netherlands. _________________ a car stops being fun when it becomes an investment |
Posted: Fri Apr 12, 2019 3:55 pm Post subject: |
If it’s a non stressed component like a water manifold I would have thought brazing would be adequate.
Art |
Posted: Fri Apr 12, 2019 4:26 pm Post subject: |
Its the part of the thermostat housing that the top radiator pipe fits on, it has to be watertite. _________________ Various Rootes Vehicles. |
Posted: Fri Apr 12, 2019 7:52 pm Post subject: |
Rooted,
Brazing is just using brass filler rod and is easily hand finished with a file and it’s cheap. That’s the way I would go.
Art |
Posted: Sat Apr 13, 2019 9:12 am Post subject: |
I am just concerned that when the pipe is re-fitted and the jubilee clip is tightened it could crack the brazing. The fracture is quite large so would require a section of metal brazed or welded back in place. _________________ Various Rootes Vehicles. |
Posted: Sat Apr 13, 2019 9:27 am Post subject: |
| Rootes75 wrote: | | I am just concerned that when the pipe is re-fitted and the jubilee clip is tightened it could crack the brazing. The fracture is quite large so would require a section of metal brazed or welded back in place. |
Big Dodge's cylinder head had an in-period brazed repair along its length, which had given way over the years, so I'd be inclined to go with something more long-lasting IMO. Is there no possibility of finding a replacement housing?
Posted: Sat Apr 13, 2019 10:18 am Post subject: |
I have adverts out in the UK looking for the housing, I have also gone out to my friends in NZ and OZ.
The housing is peculiar in only being used on this engine and only between 1948-51.
I have considered drawing up a housing to suit using a more modern thermostat and then having it machined out of aluminium. _________________ Various Rootes Vehicles. |
Joined: 14 Oct 2016 Posts: 2283 Location: East Yorkshire
Posted: Sat Apr 13, 2019 11:14 am Post subject: |
.......or, what about 3D printing? _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Tue Apr 16, 2019 4:55 pm Post subject: |
We have a 3D printer at work..... _________________ Various Rootes Vehicles. |
