Posted: Wed Apr 24, 2019 9:05 am Post subject: A Salutary Lesson |
https://forums.jag-lovers.com/t/2-years-restoration-to-2-minutes-disaster/374871
The above thread deteriorates into a discussion about fire extinguishers but the main point is that you should not test a new wiring installation by connecting it to a car battery.
I always connect a current limited power supply first so a short circuit simply shuts down the power and no damage is done. If you don't have a power supply (or even a battery charger) then at least check for shorts with an ohmeter.
Posted: Wed Apr 24, 2019 12:59 pm Post subject: |
Quite a sad tale indeed.
I suspect a lot of older cars have crusty wiring, a lot of the ones I see have them awful blue wiring connectors too.
Your idea of a current limiting device is worth heeding.
Kevin |
