johnboy183
Posted: Thu May 30, 2019 4:58 pm Post subject: Lucas NCJ101 regulator |
I am updating (!) my 1950 Sunbeam S8 motorcycle and find fitted to it (but unused) the above regulator which I understand was standard spec on 1970s Nissans.
I can find no information on this regulator and am also puzzled by the pinout. As I am fitting a Kubota PMA alternator to the bike it would be nice to know if this regulator would do the job for such a two wire single phase alternator.
Anyone that can help me with information on the regulator or hazard a guess at the pinout letters I would be very grateful.
6 Pins marked N, A, L, E, F, IG
kind regards
John |
DM
Joined: 21 Dec 2008 Posts: 214 Location: North Cornwall
Posted: Sat Jun 01, 2019 4:39 pm Post subject: |
Pinouts for the regulator are
N Stator
A Positive
L Indicator
E Negative -
F Field
IG Ignition +
However the regulator is no good to use with a permant magnet alternator, you would need to get the correct regulator to go with your alternator. |
johnboy183
Posted: Sat Jun 01, 2019 5:08 pm Post subject: |
Thank you DM - you are the first person to identify these for me (although some i had guessed). Is this for a two wire 3 phase alternator then - or what? as I thought I knew most of the common alternator pinouts.
By the way I like your Avatar as it reminds me of my very first bike (inherited from my father) which was a 1934 BSA 250cc B34 with tank change etc. Wish I still had it now
kind regards
John |
DM
Posted: Sat Jun 01, 2019 10:02 pm Post subject: |
"Is this for a two wire 3 phase alternator then - or what? as I thought I knew most of the common alternator pinouts."
Almost, as the regulator you have needs a connection from the stator terminal as well.
"By the way I like your Avatar as it reminds me of my very first bike (inherited from my father) which was a 1934 BSA 250cc B34 with tank change etc. Wish I still had it now"
It's from the 1932 B2 OHV 250 I used to have, my dad built up a B34/2 out of my left over parts. |
