Ron from Oz
Posted: Sun Aug 04, 2019 7:33 am Post subject: using an American 6Volt coil in a Morris 8/40 |
I am currently restoring a Morris 8/40 from the ground up. Although most parts came with the car, in various boxes, some are missing and some no longer work. My question for this topic is - I have recently purchased a Goss 6 V coil and am a bit stumped as to which poles to attach the leads coming from the regulator and to the distributor. The old coil was self explanatory as the SW and CB poles were clearly identified as per wiring diagram, but the new one only says + or - on the poles. The car is a +ve earth model and I was going to leave it at that - however I have no idea which pole is which in relation to the old system as shown on the wiring diagram. Any help please.
Ron |
Posted: Sun Aug 04, 2019 8:48 am Post subject: |
In my experience, the coil will work, no matter which way around the wires are connected. One way will possibly give a slightly better result, but either will work. _________________ Dane- roverdriver but not a Viking. |
Joined: 23 Nov 2007 Posts: 4284 Location: South Cheshire
Posted: Sun Aug 04, 2019 5:13 pm Post subject: |
Hi Ron
It does matter which way round a coil is fitted, fitted the wrong way looses about 20% of a coils potential, which on a 6v ignition is significant.
The marking of coils + & -ve is a far clearer way than marking sw & cb. As you car is +ve earth the switch side (sw) needs to be -ve on your new coil.
Had you picked up a coil marked sw & cb that was meant for a -ve earth car you would have fitted it incorrectly.
Ron from Oz
Posted: Mon Aug 05, 2019 9:51 am Post subject: American 6 v coil |
| Thanks guys. back to the loom for the next puzzle! |
Posted: Tue Aug 06, 2019 8:17 am Post subject: |
What is the year of your 8/40? I had a 1939 Series E many years ago and had quite a bit of fun touring in it. _________________ Dane- roverdriver but not a Viking. |
Ron from Oz
Posted: Thu Aug 08, 2019 1:44 am Post subject: Morris 8/40 |
Hi Dave,
The car is a 1948 series E. Its proving to be an interesting job as I have never had or worked on a car with a chassis. My first car in 1973 was a Citroen Light 15- a cool car, these days quite hard to get hold of one at a sensible price.
Ron |
