Positive to negative earth pros and cons?
Morepower
PostPosted: Tue Aug 27, 2019 7:58 pm    Post subject: Positive to negative earth pros and cons? Reply with quote
Hi all
My DB18 Daimler Consort arrives Monday and am compiling a list of jobs and improvements to do, what do you guys think about swapping from positive earth to negative earth? I remember doing this to a mini many many moons ago and from what I recall it was quite easy. I am thinking of car radios and charging the phone whilst out in particular.
Thanks all
Graham
PostPosted: Tue Aug 27, 2019 8:46 pm    Post subject: Reply with quote
The only advantage is as you have identified; there are far more accessories for -ve earth....
PostPosted: Tue Aug 27, 2019 8:56 pm    Post subject: Reply with quote
I agree - if you use the old tech no need to bother. If not change but make sure you identify all existing polarity sensitive accessories
Rover P2
Morris Mini Traveller Mk2
PostPosted: Tue Aug 27, 2019 11:05 pm    Post subject: Reply with quote
I heard tell....that positive earth vehicles rot less than negative earth vehicles......?? Smile
petelang
PostPosted: Tue Aug 27, 2019 11:33 pm    Post subject: Reply with quote
Important tip, if you change polarity, disconnect the Dynamo if you have one fitted, and then flash the field connection to the new positive battery terminal a few times. This resets the field and prevents potential problems with regulator points burning.
Morepower
PostPosted: Wed Aug 28, 2019 7:51 am    Post subject: Reply with quote
Thanks for your thoughts, I might go for it, if I remember correctly I have to:
Flash the dynamo (I might fit a dyanamotor)
Swap the coil leads around and swap the ammeter leads over
Have I forgotten anything?
PostPosted: Wed Aug 28, 2019 11:19 pm    Post subject: Reply with quote
If there's a clock fitted I think that might be polarity sensitive.
PostPosted: Wed Aug 28, 2019 11:28 pm    Post subject: Reply with quote
This might be stupid question but:
Would wipers try to start in the wrong direction from parked?
PostPosted: Thu Aug 29, 2019 8:24 am    Post subject: Reply with quote
Penman, I have done it on a couple of P4 Rovers that have an interesting operation for parking the wipers. They start, run and park as normal.
alanb
PostPosted: Thu Aug 29, 2019 9:35 am    Post subject: Reply with quote
Don't forget the fuel gauge,
old tourer
Morris 8 two seater
PostPosted: Thu Aug 29, 2019 7:01 pm    Post subject: Reply with quote
Whether the fuel gauge needs changing over depends on its type - most do not whether stabilised or direct. Temp gauges no need but Voltmeters and Ammeters do, Clocks vary however as do electric fuel pumps
Rover P2
Riley Blue
PostPosted: Thu Aug 29, 2019 8:08 pm    Post subject: Reply with quote
Swapped over and fitted an alternator to my Riley and now the temperature gauge no longer works - neither does the fuel gauge, but it never has. I've now got lots more electricity, don't really know what to do with it all... Smile
David
1963 Riley 1.5
1965 Riley 1.5
PostPosted: Thu Aug 29, 2019 10:03 pm    Post subject: Reply with quote
If its an SU fuel pump and has a quencher diode, the diode simply requires reversing or removing completely, if it has electronic points either swap for the new polarity or use mechanical points.
PostPosted: Sat Sep 28, 2019 6:41 pm    Post subject: Reply with quote
If you don't have the information to hand, how do you know if something is polarity sensitive or not?
I am just thinking about the petrol tank sender unit I have just bought. The instructions show negative earth but I am hoping I can just swap the wires over for positive earth?
PostPosted: Mon Sep 30, 2019 10:15 pm    Post subject: Reply with quote
The petrol gauge will either work properly or not at all. This applies to most but some may work back to front.
If there are any modern "solid-state" components they may well be ruined
Rover P2
