elliott1940
Posted: Sun Dec 08, 2019 4:46 am Post subject: Trying to ID some old classic car gauges |
I'm an aircraft nut and recently [img]bought[/img] an old aircraft gauge at an auction in the UK. In the box were a load of old British classic car gauges. I wondered if anyone here could help me ID them please?
The first is an oblong Smith's coolant gauge. I did a search and a similar but different gauge was supposedly used on an Austin A40. Does anyone know which car mine was fitted to please? I have a bunch of other bits too I'll post when I sort out pics.
Thanks for any help you can give
Joined: 31 Jul 2009 Posts: 1816 Location: Market Warsop, Nottinghamshire
Posted: Sun Dec 08, 2019 9:21 am Post subject: |
Smiths UT 1305 is for a mid-1950s Hillman Minx. You may find the following useful:
http://www.vintagebritishcables.com/documents/SMITHSSUPERSESSIONLISTBYNEW-TO-OLDNUMBER.pdf _________________ in the garage: a big empty space!
Joined: 20 Aug 2008 Posts: 1481 Location: Netherlands
Posted: Mon Dec 09, 2019 10:30 am Post subject: |
Thanks Mike for that link. A great resource. _________________ a car stops being fun when it becomes an investment |
elliott1940
Posted: Mon Dec 09, 2019 10:06 pm Post subject: |
Thank you very much for the ID mikeC, and for the link to the list. I have a few more if you do not mind?
These Smith's clocks are ubiquitous, but there is no part number I can see. Can anyone tell me what car it originates from please?
British Jaeger clock anyone?
This clock isn't on the list Mike directed me to.... The number is CE2500
elliott1940
Posted: Mon Dec 09, 2019 10:34 pm Post subject: |
SN6330/4A speedo. Not on the list....
Lucas voltage regulator
Speedo and clock. Austin A40?
Smith's clock 52550/5
Thank you very much in advance |
Posted: Mon Dec 09, 2019 11:35 pm Post subject: |
I think Austin speedo is probably from an Austin 16.
The square clock might be MG Magnette.
Posted: Tue Dec 10, 2019 9:25 am Post subject: |
| elliott1940 wrote: |
This clock was a common feature on many cars of the mid-1920s; they came in various versions - rim or remote re-wind, or hinged face with winding mechanism inside. That one looks like one used as standard fitment on Austin 12s (and no doubt many other cars) but was also available and frequently fitted as an extra to cars which did not have a clock as standard. Basically it is suitable for anything from that period!
Mog
Posted: Wed Dec 11, 2019 5:01 am Post subject: |
| Looks like you have got a good buy ! |
elliott1940
Posted: Wed Dec 11, 2019 1:22 pm Post subject: |
Thank you Mike and Peter. Now to try to get the clocks running! Can I ask one question? Is upgrading the clock movement to a quartz one frowned upon? Not original but probably more reliable...
It wasn’t cheap i’m afraid Mog |
lowdrag
Posted: Fri Dec 13, 2019 3:00 am Post subject: |
| Smiths electric clocks always been a joke in Jaguar circles since they tend to stop after the ignition is turned off and then not start again most of the time. I was driving along once and knew something was wrong and it took me some time to realise that after a gap of nine years the clock had started working!. When the car had a makeover five years ago I sent the instruments to Speedy Cables for servicing with instructions to change the clock to quartz. Now it works all the time - except when I disconnect the battery for the winter of course! It isn't possible to tell that the clock has been changed by the way - the dial is just the same. |
