Austin A30. What Engine Oil
simonA30
PostPosted: Thu Feb 27, 2020 12:22 pm    Post subject: Austin A30. What Engine Oil Reply with quote
I know I need 20w/50 mineral oil, but the prices vary so much. I am a retired retailer, and know one thing for certain, you do NOT get what you pay for, it just doesn't work like that. The oil in my 1954 A30 is now two years old, although still clear, as it has only done a few hundred miles in this time. Some people say it should be changed every year regardless of use, others may say two years, whilst there is a line of thought that says modern oils won't deteriorate in the sump like old oils did. Anyway, I'm not taking any risks, and am going to change it. The question is, with the very low mileage I do, is it really worth putting in an oil that costs £30 for 5 litres, when I can buy an API rated oil for less than half of that ?
PostPosted: Thu Feb 27, 2020 12:34 pm    Post subject: Reply with quote
I tend to stick with something from a recognised brand, but don't pay all that much attention to which brand it might be. I think regular changes are probably more important, especially if the car isn't being hammered up and down the motorway. Filter change too. I don't go for the super-cheap 20/50s, just a few £ more gets something decent.
Others opt for synthetic, it's one of those subjects where everyone has their own opinion.
Cargy
PostPosted: Thu Feb 27, 2020 1:14 pm    Post subject: Reply with quote
You could ignore the opinions, choose 124 pages of objective science by getting hold of a copy of Richard Michell’s 2011 book “Which oil? – Choosing the right oils and greases for your antique, veteran, classic or collector’s car”, Veloce Publishing.
JohnDale
PostPosted: Thu Feb 27, 2020 4:21 pm    Post subject: engine oil Reply with quote
Hi Simon, I have used Mannol Safari German manufactured 20/50 oil, API SL/CF for classic cars currently @ £17.49 per 5ltrs delivered. It is available from
lubriagecarpartsaccessories, via eBay, item 303081769185. I use this in both my cars,'58 Zephyr & '76 Granada & have used it in many other classics over time. I have never had any problems with it although I do change oil & filters annually. (Just for your info) Regards,JD.
1976 Ford Granada Ghia.
PostPosted: Thu Feb 27, 2020 4:59 pm    Post subject: Reply with quote
As an example....
https://www.classic-oils.net/Classic-Oils-Heritage-20W50
https://www.classic-oils.net/Morris-Golden-Film-20W-50
An alternative dealer I use as well
https://www.opieoils.co.uk/
Don't forget a new filter, for what they cost?
alanb
PostPosted: Thu Feb 27, 2020 9:18 pm    Post subject: Reply with quote
Halfords classic 20/50,
old tourer
Morris 8 two seater
PostPosted: Fri Feb 28, 2020 12:01 am    Post subject: Reply with quote
Hello Simon. Personally, I think it is wasteful changing the oil after just a few hundred miles. If, as you say, it is clear then leave it. I have driven many thousands of miles when I had my A30 and the engine was kept in good condition with oil changes at 3000 miles.
It is a different matter with brake fluid which should be changed every two years regardless because it is hydroscopic. Engine oil is not.
Incidentally, I always used Duckhams 20/50 but I don't know if the green stuff is still available.
PostPosted: Fri Feb 28, 2020 8:50 am    Post subject: Reply with quote
I've a feeling that it's been re-introduced in the last year or two.
PostPosted: Fri Feb 28, 2020 10:49 am    Post subject: Reply with quote
I use Morris Golden Film SAE 20W-50 Classic Motor Oil 5 Litre, a trusted brand, on offer see below at £11.75 for 5L, normally £27
https://tinyurl.com/uqk4opd
there is £4 postage, but the same if you purchase 1 or 5 cans.
JohnDale
PostPosted: Thu Mar 05, 2020 4:57 pm    Post subject: Reply with quote
Hi Alanb I believe it's Comma 2050 redressed in new clothes for Halfords as they don't make engine oil,all the best,JD.
PostPosted: Thu Mar 05, 2020 7:55 pm    Post subject: Reply with quote
Nothing wrong with Halfords Classic / Comma 20/50 or such like. Ideal for the A series.
alanb
PostPosted: Thu Mar 05, 2020 8:40 pm    Post subject: Reply with quote
Just bought 10 litres of Morris golden film 20-50 £28 including shipping as per Ukdaves post https://tinyurl.com/uqk4opd
old tourer
Morris 8 two seater
